06-02-2021, 07:50 PM | #1 |
Bending the front axle
Does anyone know if you can bend the front axle? My left front tire leans inward about !/2 inch.
06-02-2021, 08:14 PM | #2 |
Re: Bending the front axle
Yes. Bend cold. You are going to need some big force. Use the gauge rods that mount in the four holes. See "Adding Caster to the Axel" https://www.fordbarn.com/forum/showt...ster&showall=1
06-02-2021, 09:12 PM | #3 |
To a truck repair workshop, bending a Model A axle is like breaking a pretzel.
06-03-2021, 10:06 AM | #4 |
Are you sure that it's the axle? I had a similar problem where it was the spindle.
If you don't hear a rumor by 10 AM, start one!. Got my education out behind the barn! Last edited by katy; 06-03-2021 at 10:07 AM. Reason: Addition |
06-03-2021, 10:46 AM | #5 |
Not only the spindle, but also the king pin or a combination of both. I would certainly
check those out before pulling the axle.
IN GOD WE TRUST - SEMPER FIDELIS John |
06-03-2021, 10:52 AM | #6 |
Maybe they could do the same for you with the axle still in the car? |
Thread Tools | |
Display Modes | |
