04-23-2021, 06:47 PM | #1 |
Spare Tire In the Wheel Well
Am I supposed to put that tire assembly into the wheel well -- without any air in it, or what? That's a real bitch when it's fully inflated.
Thanks |
04-23-2021, 07:10 PM | #2 |
Re: Spare Tire In the Wheel Well
unless you have a tire pump with the car, letting air out can be risky if you're like me and will do my own flat tire changes when needed. Try a water/liquid soap sprayer on the tire then try wedging it in. They were a tight fit when new. Hopefully the tire is the correct width for your "A".---Pete.
04-23-2021, 07:23 PM | #3 |
I put mine in slightly deflated so it’s still useable in an emergency . I then get it inflated ASAP. I also carry a can of Fix a Flat but I’ve never used it.
04-23-2021, 08:05 PM | #4 |
On my long-gone pickup, I deflated the tire a bit to get it in the well, then reinflated it to correct pressure. Sounds strange but it would come out of the well OK when fully inflated.
04-23-2021, 09:01 PM | #5 |
