Old 11-05-2014, 07:14 AM   #1
BILL WZOREK
BILL WZOREK's Avatar
Default Valve spring shims ~~~
Valve spring shims:
When / where do they go and why ( I think I have the last part )
My Bucket list has many ~ many questions besides going & doing things.
THANKS EVERY ONE ~ ~
BILL WZOREK is offline   Reply With Quote
Old 11-05-2014, 07:24 AM   #2
41ford1
41ford1's Avatar
Default Re: Valve spring shims ~~~
The washers are used to set valve seating pressure. Check some of Ol' Ron's postings. They go between the spring and guide on a flathead or the spring and head on an OHV.
You are never to old to enjoy your childhood.
Forty1fordpickup on the HAMB.
41ford1 is offline   Reply With Quote
Old 11-05-2014, 07:42 AM   #3
51 MERC-CT
51 MERC-CT's Avatar
They are necessary when using GM valves which are longer to achieve the correct pressure,
Old 11-05-2014, 07:57 AM   #4
BILL WZOREK
Ok when you check the spring pressure in the spring tester.
How much compression to get the proper # pressure of the spring?
Old 11-05-2014, 07:59 AM   #5
cadillacoffin
Do you guys find that the new isky springs to vary much?
cadillacoffin is offline   Reply With Quote
Old 11-05-2014, 08:30 AM   #6
51 MERC-CT
51 MERC-CT's Avatar
On my 51' Merc, the specs. are 40#- 43# @ 1.89" (suspect Fords are the same )
Old 11-05-2014, 09:22 AM   #7
Ronnie
Ronnie's Avatar
Here u go
https://www.hastingsmfg.com/ServiceT...ng_inserts.htm
R
Ronnie is offline   Reply With Quote
Old 11-05-2014, 01:44 PM   #8
Ol' Ron
Ol' Ron's Avatar
That sounds kinda high. I used one .060" shim on a rotating valve assy to get #55/60 with stock springs and Max#1 cam. Engine has been running now for over 10 years.
Old 11-05-2014, 01:57 PM   #9
51 MERC-CT
51 MERC-CT's Avatar
You are correct, I made a mistake and copied the figures for the Lincoln EL engine, For the 51 Merc. it should be 40#-43# @ 1.89"
Old 11-05-2014, 02:39 PM   #10
BILL WZOREK
THANKS GUYS !!!
Not building Just a Question that I Now Have a answer to.
I hope every one don't mind answering Questions that may
seem like general knowledge to a lot of you ~~~
Thread Tools
Display Modes
