Old 08-14-2014, 05:21 PM   #1
cadillacoffin
Default Merc banjo axle
It is my understanding that some of the merc pinions were welded to the drive shaft. Does anyone have a picture of this? Did they weld the coupler at both ends? Were the shaft and pinion splined?
Trying to figure out if a merc ring and pinion will work for a quick change.
Thanks!
cadillacoffin is offline   Reply With Quote
Old 08-14-2014, 05:26 PM   #2
Ken/Alabama
Ken/Alabama's Avatar
Default Re: Merc banjo axle
Don't think it was welded. I do believe it's all made together. I'm thinking that they did that from 39 -41 but not positive.
Ken/Alabama is offline   Reply With Quote
Old 08-14-2014, 05:46 PM   #3
Karl Wolf
Karl Wolf's Avatar
I have two sets of them, the pinion gears and drive shaft are machined from one piece of steel. So that the pinion gear is 4-5 feet long. The 1946 is a 3.54 ratio, the 1947 is 3.78.
I would trade the 3.78 for another 3.54.
Karl
Karl Wolf is offline   Reply With Quote
Old 08-14-2014, 09:48 PM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
What was their logic for a one piece driveshaft and pinion used by Mercury?
John
Old 08-15-2014, 12:01 AM   #5
ford38v8
ford38v8's Avatar
Just speculation here, but you must remember that old Henry Ford was always on the prowl for a quicker assembly, less complicated technology, fewer parts automobile. He always got his way, even when he was dead wrong.
Alan
Old 08-15-2014, 09:04 AM   #6
rotorwrench
rotorwrench's Avatar
The Mercury was a slightly heavier car with a slightly higher HP engine and I figure it was to eliminate the spline coupling that was one of the weak points in the Ford design. They only used it for a short time so the spline coupling won out in the end.
They can be cut down and reslined if the diameter of the shaft is compatible with the normal six spline pinions.
