06-06-2021, 07:43 AM | #1 |
Aluminum hood question
The steel hood on my 1930 Fordor is hard for me to lift off when I have to do that for certain repairs. There was an aluminum hood available for my 1915 Model T that was really light. Are there aluminum hoods available for Model A's?
06-06-2021, 07:55 AM | #2 |
Re: Aluminum hood question
To do it safely (for the paint and me) by myself, I've used my engine hoist.
06-06-2021, 08:47 AM | #3 |
I have a 1914 Model T with an aluminum hood. Yes it is light and easy to remove. The hood is actually only held to the car by the hood clamps! Unfortunately, it is prone to stress cracking. I eventually had to take it to a shop and have the cracks welded up and ground back and then had to match the paint and repaint it.
Two people should lift a hood off of the Model A. Ed |
06-06-2021, 10:05 AM | #4 | |
Previously some one on here mentioned pulling the hinge pins out of the hood and removing the hood in pieces.
06-06-2021, 10:11 AM | #5 |
Rig up rope and pulleys to remove your hood by your self, it maybe better than with help. Park the hood right above out of the way, don't move the car and when done lower back down.
06-06-2021, 10:53 AM | #6 |
06-06-2021, 11:18 AM | #7 |
The hoist is a good idea, thanks. I take it from the comments that aluminum hoods for Model A's are not available. One other option, I guess, is to acid dip the hood to reduce the metal thickness. That is (was) done on race cars.
06-07-2021, 04:59 AM | #8 |
06-07-2021, 05:59 AM | #9 |
