10-23-2021, 10:46 AM | #1 |
1939 Ford Vert Cowl Vent will not budge
Can't open the vent to let in fresh air. Don't want to force it and break something. Click on pic to expand. Need advice Thanks!
1939 Ford Cowl Vent under dash 1.jpg 1939 Ford Cowl Vent under dash 2.jpg 1939 Ford Cowl Vent under dash 3.jpg |
10-23-2021, 10:52 AM | #2 |
Re: 1939 Ford Vert Cowl Vent will not budge
Most likely the lid seal is stuck. I would disconnect lid from mechanism to verify which is the problem and prevent damage.
10-23-2021, 11:02 AM | #3 |
Looks like someone did some home made rehab on the vent mechanism. Do as marko39 says and then spray all the mechanical parts of the vent with WD-40 or PB Blaster to free things up. Previous owner may have tightened all the movable opening parts tight so vent couldn't be opened. It looks like someone tried to seal the vent closed. If the 39 vent mechanism is the same as the 40, I can send post photos of how it looks originally from the factory..
10-24-2021, 08:03 AM | #4 |
Thanks
10-24-2021, 09:10 AM | #5 |
Ramblin Reck: Here's a thread that may help.
https://www.fordbarn.com/forum/showthread.php?t=40854 |
10-24-2021, 12:11 PM | #6 |
10-25-2021, 09:48 AM | #7 |
10-25-2021, 10:13 AM | #8 | |
You betcha it helps! Thanks! |
10-25-2021, 09:37 PM | #9 |
I had a similar problem years ago everything had to come apart then lastly pushed open the vent. Bottom line it all had to come apart
10-25-2021, 10:48 PM | #10 | |
10-26-2021, 07:02 AM | #11 |
Appears the vertical portion of the door is bent and interfering with the screen. It should have been bolted to the hinge in four places and is not. I also suggest you take the inside portion apart to see if you can get it straightened out. The screen already has a hole in it so don't be afraid of damaging it since it is reproduced and common to the 40
10-31-2021, 04:21 PM | #12 |
mine was a bear too. lots of PB Blaster
11-01-2021, 01:56 PM | #13 |
Had this problem on my 37. Soaked it from top side with WD40. A day later it broke loose.
