Old 02-12-2024, 03:36 PM   #1
hlhpa
Default EE-01 carb base
Hello; a new guy,Working on some Ford 97s. Hopefully I can put some pictures here. Or how do I put picture here? there is a brass plug that comes out of the EE-1 base. But not on all of the bases ,have a plug. the fuel bowl has a notch to accommodate the plug. Question what does do? is it needed? When I bought these carbs, trying to get enough parts to a build good, there was a 97 look alike, that had 1 1/2 stamped on the side. What is that? I was hoping it was some rare carb, I could sell and retire.
Thanks for your forum and input.
Howard
I did not figure out how to put picture up.
hlhpa is offline   Reply With Quote
Old 02-12-2024, 03:54 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: EE-01 carb base
Howard
hlhpa ..... BELOW is a tutorial that I came up with some time back to help members post pics here on the 'Barn. And a big WELCOME to FordBarn! Click the link BELOW!!
Coop
https://www.fordbarn.com/forum/showp...&postcount=649
Click Links Below __
T5 W/TORQUE TUBE
Old 02-13-2024, 09:00 AM   #3
Terry,OH
Terry,OH's Avatar
The EE-1 is usually marked such and also with a Pxxxxx number which is Stromberg's part number which may be very hard to read.
Brass Plug ?? and a notched float bowl for clearance ?? would like to see photo.
Have you mis-labeled the middle casting skirts with a notch and the base with an extra brass nozzel in the ventura? If so the base is from a 97 made in Elmira, NY and not South Bend. Don't use the EE-1 with the extra nozzel with the South Bend 97 body
Old 02-16-2024, 10:29 PM   #4
hlhpa
See the pictures, what I thought was a plug, is a vent to the idle circuit. this is on the bases thst are sculptured, the solid larger bases are different and do not have this extra vent. What are the years? thanks Howard
Old 02-16-2024, 11:51 PM   #5
petehoovie
petehoovie's Avatar
Attachment 536618Attachment 536619
Old 02-17-2024, 05:26 AM   #6
nickthebandit
According to what Max Musgrove told me that bowl and base are the improved idle circuit assembly. If you mix and match these components with a regular EE-1 base or Venturi the carburetor will not operate correctly. If you would rather have the regular EE-1 base and carburetor body, I will gladly trade you as I have a customer that prefers that type of base and body.
nickthebandit is offline   Reply With Quote
Old 03-25-2024, 09:04 PM   #7
hlhpa
Working on this 97 carb and the needle and seat threads have been enlarged. will a 7/16th -20 helical fix this?
thanks Howard
Old 03-25-2024, 10:21 PM   #8
petehoovie
petehoovie's Avatar
Attachment 539110
thanks Howard
Old 03-26-2024, 04:49 AM   #9
nickthebandit
A 7/16-20 heli-coil may fit, but it is incorrect. The correct thread is 7 /16-28 which is a non-standard thread that Ford used for their Stromberg carburetors. You best bet is to send your carburetor bowl to Max Musgrove for a proper inlet thread repair. Max has done this for many people including me.
Old 03-26-2024, 09:44 AM   #10
deuce_roadster
deuce_roadster's Avatar
Welcome to this forum. No matter what the problem is, you may get many opinions on how to solve it but there are some VERY knowledgeable people who can direct you to or explain the best way to solve it. People like nickthebandit and V8coopman are good examples.
Old 03-26-2024, 09:48 AM   #11
hlhpa
How do I contact Max Musgrove?
Old 03-26-2024, 12:19 PM   #12
deuce_roadster
Here you go:
MAX MUSGROVE – 97 EXPRESS
1173 South 1100 East
Salt Lake City
UT 84105-1815
Telephone: (435) 322-0102
Email: [email protected]
www.97-express.com
Old 03-27-2024, 06:55 AM   #13
alchemy
alchemy's Avatar
Email Max, don’t call. And he will fix you up.
alchemy is offline   Reply With Quote
Old 03-28-2024, 09:36 AM   #14
Andy
I made my own inserts. I forget what thread I used, but I tapped the bowl out to fit. I used a fine thread bolt. I drilled and tapped the bolt with the correct tread for the seat fitting. The fitting still sealed on the housing as the insert was below the boss. I did not finish tap the bowls. I left some untapped length so the insert could not screw thru.
I did quite a few this way. Never a problem.
Andy is offline   Reply With Quote
