08-13-2011, 04:07 PM | #1 |
Looking for tips on installing clutch release fork
I need to install the clutch release shaft and fork in my aluminum bellhousing adapter. I plan to heat the fork and cool the shaft but I am looking for tips on how to actually assemble it.
Thanks -Don |
08-13-2011, 05:51 PM | #2 |
Re: Looking for tips on installing clutch release fork
schould not be nessery to heat if your talking about 32-48 shaft & fork it schould be a slide fit without heat then a pin goes through the fork. some guys use a grade 8 bolt
08-13-2011, 11:48 PM | #3 |
Richard is exactly correct. Bushings may need reaming/honing to fit. You may also want to add Zerk fittings to the bushing areas so you can later grease them.
08-14-2011, 09:46 AM | #4 |
