07-16-2017, 09:50 AM | #1 |
So I bought my new motor yesterday...
So I found a C69A block, crank, pistons, rods, etc., all disassembled and bought the works for $500CDN (sadly this is only about $375USD these days).
A couple of concerns, the main one being the broken (and repaired) bellhousing. The crank is scuffed and may need to be turned. The good: It is all apart and clean (apparently checked for cracks and good to rebuild). The bores are all clean and I measured them to 3.274" (the pistons are used and I haven't measured them yet. I don't really recognize the valve reliefs - if anyone has info on those, I would appreciate your knowledge. Thoughts? Thanks, George |
07-16-2017, 09:54 AM | #2 |
Re: So I bought my new motor yesterday...
sorry, here is a few more pics...
07-16-2017, 09:57 AM | #3 |
Are those hairline cracks below the studs in the block normal?
07-16-2017, 10:03 AM | #4 |
.086" over? That's a funny size. The bellhousing looks like a workable repair, from what can be seen in that pic. It looks like it has the second boss bored in the oil distribution area. Check to see if the horizontal passage has been blocked off.
Mart. |
07-16-2017, 10:09 AM | #5 |
Been running my 59 AB for 17 years with the same corner missing off the bell housing. I'll take a chance and say that your repaired bell housing should be fine.
07-16-2017, 10:13 AM | #6 |
07-16-2017, 10:20 AM | #7 |
Here is the oil boss area... (and the crack )
07-16-2017, 10:37 AM | #8 |
I wouldn't worry about that repaired bellhousing.
Looks like it was a good job. |
07-16-2017, 11:16 AM | #9 |
07-16-2017, 11:32 AM | #10 |
So, I was going through the boxes of spare parts that came with the engine and there are 16 small ford parts boxes PN 8N6500.
these are all new adjustable lifters, the mystery is that 8 of them are solid and 8 of them are hollow? A mistake? |
07-16-2017, 11:55 AM | #11 |
(I'm no expert) Those sound like the 8N tractor lifters. They are 4 cylinder motors so would have been used in sets of eight. Maybe bought in 2 sets of eight hence two different types. They may have been equivalents of each other, so not numbered differently by Ford.
Kinda guessing. Mart. |
07-16-2017, 11:59 AM | #12 |
I just took a look at the pistons and they are 4 ring dome type which measure 3.263"
there is a set of new rings with them and they are marked .080 the rods include 3 marked 29A, 1 marked 99A and 4 are "I dunno". *note bonus: I found 16new TRW valves and a set of new TRW Cam bearings. It looks like someone had been getting the parts together to doa rebuild on this engine. |
07-16-2017, 03:30 PM | #13 |
ford tractor adjustable lifters are very heavy as compared to Johnson adjustable lifters. I am using a set of these right now and have had no problems with them
07-16-2017, 05:31 PM | #14 |
Your 95 % oil flow hole looks a bit small .
Upon advice from here, I tapped both holes to I think 3/8 BSP, so there is a full 7/16ths hole thru and no extra restriction from standard. oil gallery size to and from the filter. |
07-16-2017, 09:01 PM | #15 |
My current block has a broken and repaired bellhousing.
07-17-2017, 07:11 AM | #16 |
Seems like a lot of broken and repaired blocks, but it sounds like a useable piece (making me happy ).
07-17-2017, 09:38 AM | #17 |
Sounds to me like you got a screaming deal when you bought that engine. That's a lot of good stuff there!
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
07-17-2017, 05:14 PM | #18 |
Mine is a C69A too.
A guy told me a very good block with thicker cylinder walls....dunno if this is fact or not. |
07-17-2017, 05:40 PM | #19 |
Indeed a fact!
07-18-2017, 02:23 PM | #20 |
I noticed the crank only has a single oiling hole on the rod journals - I believe this is for full floating rod bearings $$$ (Reds has them for $425). I thought I read here that I can use the 29A rods with a newer crank with insert rod bearings - is that feasible?
