Old 06-20-2016, 05:32 PM   #1
GAR64
Default Replacing Dash Panel
Just got a new dash panel from Bert's for my 29 tudor. I haven't gone out to take it apart yet but was wondering how all the electrical connections are made for the amp meter, ignition, and speedo. Soldered joints, nuts, wire nuts? I am guessing they may be old and brittle and want to make sure I put it together clean and safe. Little by little this car is looking better and better.
GAR64 is offline   Reply With Quote
Old 06-20-2016, 05:35 PM   #2
dalton
Default Re: Replacing Dash Panel
Electrical connections are made with nuts. The speedo is mechanical. If you're concerned with the age/condition of the wires, why not order a new set from your favorite vendor?
dalton is offline   Reply With Quote
Old 06-20-2016, 05:48 PM   #3
Big hammer
Disconnect the battery before working on your dash!
Big hammer is online now   Reply With Quote
Old 06-20-2016, 06:09 PM   #4
Mitch//pa
12.00 for the dash harness... And at the same time you'll be going over the junction box connections cause it connects into there....
It's a no brainer to replace it
Old 06-20-2016, 06:31 PM   #5
GAR64
I planned on disconnecting the battery. But I don't understand Mitch's comment. Where does the dash harness connect. Twelve bucks is cheap but what else will I get into..
Old 06-20-2016, 06:38 PM   #6
Mitch//pa
This is from brattons
Old 06-20-2016, 06:43 PM   #7
dalton
Just the other end of that harness. It's in the junction box on the firewall. If you are concerned about the conniption of the other wires also, order the cutout to terminal wire and the coil to terminal wire. About another $12.
Old 06-20-2016, 06:44 PM   #8
kbinde2
kbinde2's Avatar
Being a "newbie", I might add a comment. I just replaced the terminal box wiring (dash), and the terminal to cut-out wiring this past wk-end. Easy job with all the diagrams/wiring info thru vendor/MAFC and forum information found here. I had a bare fire-wall and had already removed the dash to get rid of hidden wasp nest/critter litter, and any brittle or ?? wiring.!
kbinde2 is offline   Reply With Quote
Old 06-20-2016, 06:48 PM   #9
Mitch//pa
And if you have the replacement style ignition switch already (not a pop out) put in this quality pop out look alike with cable since your already there
Poor quality ignition switches are known to fail...insulate the terminals as they can touch the gas tank and short
Old 06-20-2016, 06:55 PM   #10
GAR64
Thanks you guys. I am going to pull the old dash and see how things look and go from there.
Old 06-20-2016, 07:01 PM   #11
Mitch//pa
Make sure the posts coming out of the ammeter are not loose... This is one I'm working on now .. The meter and wiring fried....
Old 06-20-2016, 07:04 PM   #12
GAR64
I am looking at that pic of the ammeter. Do those caps thread on??
Old 06-20-2016, 07:06 PM   #13
Mitch//pa
Yes thumb nuts... Sometimes they are missing and the person hex nuts them...
These particular ones were melted and fused
Old 06-20-2016, 07:14 PM   #14
loubob
yes.
where is 'upstate,ny?'
loubob is offline   Reply With Quote
Old 06-20-2016, 07:36 PM   #15
GAR64
I am near Albany.
Old 06-21-2016, 05:36 PM   #16
GAR64
I took the dash off and everything seems ok although I have not removed anything yet. I see that they sell a tool for use in replacing the gas gauge. I bought new inner and outer nut. I guess I need that tool to remove inner nut?? Can I just replace the nuts or will I need a gasket set? Gauge works fine ( or as well as it is supposed to). I just want to add new chrome inner/outer nut to look nice on new panel. I think I better order ALL the little things I need before starting this job...
Old 06-21-2016, 05:48 PM   #17
Mitch//pa
The repo nuts don't have the right thread pitch and have been a real problem lately.. Beware and don't try to force them on...
u need a cork gasket set not neoprene because of the ethanol.
And while your there replace the float with an ethanol fuel proof one
