02-20-2017, 03:42 PM | #1 |
1933 V8 Freeze Plugs????
Please see previous post. The last pic is a duplicate of the third one.
Thanks |
02-21-2017, 12:20 PM | #2 |
Re: 1933 V8 Freeze Plugs????
Doug, Have come across so many rotten freeze plugs and so much tar like pan sludge in these flatties over the years that I pull the oil pan on every one for a clean out and new freeze plugs. Don't miss this opportunity to clean out your water jackets with some coat hangers or threaded rod and a shop vac.You won't believe the crud on the other side of those freeze plugs.
02-21-2017, 01:24 PM | #3 |
With respect, plugs that are securely retained by the attached adjacent oil pan flange aren't exactly "freeze" plugs as noted at the top of the first post.
02-21-2017, 01:35 PM | #4 |
None of them are "freeze" plugs, they are core plugs to get the core sand out of the casting! Sometimes a few have been lucky they popped when frozen, not very often.
02-21-2017, 01:43 PM | #5 |
