05-28-2016, 06:28 PM | #1 |
Resistor question
Just a quick question before I proceed.
Currently running a "modern" coil in stock '47 V8 installed by previously owner. Looking under dash, it appears he bypassed the original resister, I assume, because 2 wires are on one post. Going back to the original style of Ford coil for the year (1GA 12024). From reading previous posts, I will need to put the resistor back in the loop. 1. Is there a polarity of this resistor? 2. Is there an easy way to check this resistor with a multi-meter? 3. What values? Just got a Bubba's distributor and don't want to burn up the points. Thanks |
05-28-2016, 06:54 PM | #2 |
Re: Resistor question
Yes you need the resistor back in the circuit. Really no need to check the resistance, but believe it is somewhere around .5 ohms. There is no polarity to a resistor. You might check the resistor using the ohm setting on your meter just to make sure it will conduct.
05-29-2016, 06:26 AM | #3 |
Thanks.
More questions. Just swapped out the coil, connected the resistor and fired it up with no problem. (Still using the old distributor). Noticed the under-dash resister is hot. Read other posts and understand that is how they work. Question. Will the heat increase with sustained running engine, or will it stabilize to a point? Last edited by topchop; 05-29-2016 at 06:40 AM. Reason: edited for clarity. |
05-29-2016, 07:15 AM | #4 |
As the resistor heats up the current goes down through it and it comes to a normal running temp.
05-29-2016, 07:38 AM | #5 |
