Old 01-15-2022, 02:13 AM   #21
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 39 pedals in a 36 frame
Originally Posted by 36coupe View Post
DD sent me the template. I think I will go to town to buy some ink for the printer. The rearward hole that orientates the location of the brake pedals must be the same on all 35-40 frames.
I do not have a 39 clutch arm, so will have to try find one. (I’ll buy one if anybody has an extra one laying around)
Bob Drake no longer lists the brake pedals or 39 clutch arm. Seems like they are fazing things out.
Lindsay .....I was just snooping-around in some notes that I had written to myself some years back noting to myself that you MIGHT do better by using the TOP, REAR hole as the one to index off of.
I FINALLY found this image that shows why the '39 clutch arm is angled off to the left. This is a '39 pedal set in the picture BELOW.
Below is a comparison of all the different clutch arms. You can see why the height & angles can make a difference. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-15-2022, 02:24 AM   #22
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by Tinker View Post
I have 39 pedals in my 36. No issues. Respect your opinion.
See what pedals you have and assess.
Here we have a '39 pedal set with the FORGED Clutch arm....which CAN BE HEATED and bent. DD
T5 W/TORQUE TUBE
Old 01-15-2022, 02:43 AM   #23
V8COOPMAN
V8COOPMAN's Avatar
DD sent me the template. The rearward hole that orientates the location of the brake pedals must be the same on all 35-40 frames.
As far as exact placement goes, I've noticed in a couple of pictures that I have that the UPPER, REAR bolt seems to be directly below the recess, or indent on top of the frame rail for the counter-sunk bolt that retains the stay rod which prevents the engine's fore & aft movement. You have to look closely in this first picture. That UPPER, REAR bolt can be seen just above the right end of the big spring.
This second picture BELOW also shows the UPPER, REAR bolt in bracket to be just below the same, beveled recess for the counter-sunk stay rod bolt on TOP of this chassis rail. DD
T5 W/TORQUE TUBE
Old 01-15-2022, 02:59 PM   #24
38bill
38bill's Avatar
The bottom photo is my '38 1/2T pickup. I used the Bob Drake template for the location of the '39 pedals. Everything lined up perfectly except the clutch shaft arm. I ended up just making a longer clutch shaft that located the stock clutch arm inline with the clevis on the clutch pedal.
38bill is offline   Reply With Quote
Old 01-17-2022, 11:17 AM   #25
'36 5W
'36 5W's Avatar
Late to the party here, but wanted to thank everyone for the
additional info. ("Fine print"), and great D/D/'s closeups of Peter's
beautiful '35 chassis, (LOVE that car!).
When I started to mock up this same combo. in my '36 a few years
back, I could see it was not going to be the "bolt-in" swap some
had mentioned. Now I can see the pedal holes in the Carpenter
toe boards are probably not going to align either. Just another
little glitch in getting the puzzle pieces to all fit together!
'36 5W is offline   Reply With Quote
Old 01-17-2022, 12:33 PM   #26
Karl Wolf
Karl Wolf's Avatar
I don't see Richard Lacy mentioned any where on this post.
He has a business and makes kits for changing over to hydraulic brakes.
A friend installed one on a 1935 Ford, quite nice- and no mods to the car at all.
The business name may be The V8 Garage (corrections most welcome).
Karl
Karl Wolf is offline   Reply With Quote
Old 01-17-2022, 03:34 PM   #27
bobH
Karl
Yeah... When I read all the stuff these guys are discussing, seems to me I'd consider taking the easy way out... keep stock pedals, and look carefully at the way Richard does it. 'Course, I'm somewhat of a 'fan' of the way Richard does it. Sure, costs a little, but to me, worth it.
bobH is offline   Reply With Quote
Old 01-21-2022, 12:29 PM   #28
36coupe
36coupe's Avatar
I still have lots to do but it is now a roller. Next thing I will do is install the Vern Tardel rear drum retainers and run my brake lines.
After that I will get the body on the rotisserie and clean the underneath and ready the underside for paint.
File Type: jpg 5F623A2E-7F12-4D1F-A44A-F1BD85EF8FD8.jpg (71.9 KB, 55 views)
File Type: jpg DA0A36CD-E900-4DAA-9F59-B6E370ACD4A6.jpg (69.4 KB, 45 views)
File Type: jpg 0AAF61D2-EFB6-4611-9843-405DD669C7E2.jpg (58.0 KB, 41 views)
36coupe is offline   Reply With Quote
Old 01-21-2022, 05:50 PM   #29
36coupe
36coupe's Avatar
Drum retainers and gravel guard
File Type: jpg 646BFE8F-BC3E-4F49-8C02-3DD13198183D.jpg (45.5 KB, 45 views)
Old 01-30-2022, 09:35 AM   #30
36coupe
36coupe's Avatar
I made a bit more headway running the brake lines. I had to order some fittings from third GEN. I fabricated two brackets to hold the hose ends to the frame and was able to drill a hole through the inner fenders. I had lots of gravel guard left over so I use some on the brake lines next to the master cylinder.
Old 01-31-2022, 12:11 AM   #31
Tinker
Tinker's Avatar
Originally Posted by V8COOPMAN View Post
Well....NOT necessarily so, Tink! See my post ABOVE about CAST, I-beam type pedals! DD
Yep... as I originally said heat them and bent them... or just use every moment you have to run me down.
Old 01-31-2022, 12:11 AM   #32
Tinker
Tinker's Avatar
Grade 8 bolts are really designed for forces that apply vertical force. Pull. Not great for shear. That said they are fine for what you are doing.
I wouldn't worry about torch bending the pedal. Just my opinion. They are forged not cast.
Old 01-31-2022, 01:00 AM   #33
Tinker
Tinker's Avatar
Looks great! Nice work
Old 01-31-2022, 10:50 AM   #34
Zeke3
Zeke3's Avatar
Lindsay, is that the stoplight pressure switch in the front brake circuit? If you lose pressure to the front brakes, you will also lose the signal for your brake lights. You might consider a mechanical brake light switch rather than a pressure switch.
Zeke3 is offline   Reply With Quote
Old 01-31-2022, 01:13 PM   #35
V8COOPMAN
V8COOPMAN's Avatar
TINKER ....As I originally said, the Ford pedals with an I-beam cross section are "CAST"-iron. As far as "running you down"....I COULD say that you make it easy to do when you continually get your information from WHO KNOWS WHERE, but I am here with hopes of sharing REAL information with those interested in hearing such. Check this little quote from "DavidG" just 15 months ago about "cast-iron" Ford pedals. PLEASE click the link BELOW. DD
https://www.fordbarn.com/forum/showp...1&postcount=18
T5 W/TORQUE TUBE
Old 01-31-2022, 02:41 PM   #36
36coupe
36coupe's Avatar
Yes, I’ll probably leave it in the plumbing. I can’t hook,up a mechanical one until the body is back on.
Old 01-31-2022, 02:42 PM   #37
36coupe
36coupe's Avatar
My brake pedal is forged and the clutch is cast.
Old 01-31-2022, 08:25 PM   #38
FlatheadTed
FlatheadTed's Avatar
We have just done this heres s a whole thread on pedals
https://www.fordbarn.com/forum/showt...9+pedals+David
http://www.flatheadted.com
Flathead Ted brake Floaters ,
