Old 11-29-2021, 07:41 PM   #1
cajunfirehawk
cajunfirehawk's Avatar
Question 1936 tudour clutch & brake springs, just 2?
My 36 has been down for a while after selling and moving from our last home and last time I adjusted the clutch I either misplaced a spring OR, put the clutch spring in the wrong location so it doesnt have enough tension on it?? Now the clutch is super easy to push which I know isn't correct. Currently there is one spring for the brake pedal and one spring for the clutch pedal but I feel like I am missing one Its hell when you get old is there just two springs total or three???
Thanks!
(attached is the only pic I could find but I still feel like there was a 3rd spring?)
Regards,
Todd
1936 FORD Tudor Slantback
"cajunhotrodder" on instagram/youtube
cajunfirehawk is offline   Reply With Quote
Old 11-29-2021, 08:10 PM   #2
petehoovie
petehoovie's Avatar
Default Re: 1936 tudour clutch & brake springs, just 2?
Thanks!
Old 11-29-2021, 08:57 PM   #3
Brian
Brian's Avatar
Just the two as you show.
Old 11-30-2021, 07:51 AM   #4
Terry,OH
Terry,OH's Avatar
Both the clutch and brake pedal return are identical 3.44" 48-7523
Old 11-30-2021, 09:13 AM   #5
rotorwrench
rotorwrench's Avatar
If it is too easy to push then I'd also be wondering about the pressure plate.
Old 11-30-2021, 05:26 PM   #6
cajunfirehawk
Yes, but the kicker is I don't remember it this easy before I messed with the springs which leads me to the next question;
Its understood that the end of clutch spring connects to the end of the adjustable fork on the engine side but if I remember correctly I just have the other end connected to what looks like a bracket, does that sound correct
thanks again!
Regards,
Todd
