Old 11-28-2021, 09:17 PM   #1
Jonmiller128
Default Radiator support 48-50 vs 51-52 F1
Is there a difference between the radiator support in a 48-50 F1 and a 51-52 F1?
Jonmiller128 is offline   Reply With Quote
Old 11-29-2021, 07:32 AM   #2
Gick70
Default Re: Radiator support 48-50 vs 51-52 F1
Well I can't say anything about the support but they all take the same radiator..
Gick70 is offline   Reply With Quote
Old 11-29-2021, 01:26 PM   #3
Bob C
The parts book show the same 1948-52.
Old 11-29-2021, 03:08 PM   #4
Jonmiller128
Thanks for the info. I thought so, but simply couldn’t find a definitive answer
Old 11-30-2021, 09:14 PM   #5
JHFORD51
Actually the 48 to 50 supports have two small holes in the upper left hand side front ( just under where the sheet metal air deflector passes through the upper bolt) to mount the 48 to 50 horn and bracket. Those two little holes were eliminated in 51 when the horn or horns (hi and lo on the deluxe cab) were mounted on the hood.
Otherwise same/same 48 to 52 F1 to F6 conventional cab.
JHFORD51 is offline   Reply With Quote
