Old 02-07-2021, 03:50 PM   #1
harleycontracter
Default Hole in the floor ?
I know there’s a logical simple answer. What is the elongated hole in the wood floor for ? It’s near the battery but you can’t really access or remove the battery from there Was trying to post a pic but ....
harleycontracter is offline   Reply With Quote
Old 02-07-2021, 03:58 PM   #2
MAG
MAG's Avatar
Default Re: Hole in the floor ?
That hole is access to allow checking the electrolyte level in the battery cells. The hole is covered by a metal plate held in place with metal clips.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 02-07-2021, 03:58 PM   #3
Big hammer
Battery access, to service water or jump start, there should be a panel to cover the hole.
get a bigger hammer tap done
Old 02-07-2021, 03:59 PM   #4
harleycontracter
I just bought the plate Got it Makes sense Thank you
