Old 06-13-2021, 12:56 PM   #1
Reds34
Default Difference between '33 and '34 truck grilles
I was wondering what the difference is between a '33 and '34 truck grille. I have this one listed in the swap meet as a '33 for the reason that it came off a '33. I have gotten a pm letting me know that it's a '34. How do I tell?
Thank you.
Red
Reds34 is offline   Reply With Quote
Old 06-13-2021, 02:55 PM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: Difference between '33 and '34 truck grilles
Not positive but I believe the differences are near the bottom, along the sides.
Old 06-13-2021, 03:04 PM   #3
deuce lover
deuce lover's Avatar
33's for one don't have the stainless trim
Old 06-13-2021, 03:16 PM   #4
2ndgeer
2ndgeer's Avatar
Your grille is for a 1934. It has the embossed protrusion on the top for the chrome bezel that extends to the radiator cap. The 1933 grille does not use a bezel and on the 1933 the Ford insignia fits into a simple embossed surround oval.
On a 1933 grille the center reinforcement that supports the teeth is pressed from the teeth themselves. On the 1934 grille the support is a separate thinner piece that is crimped to the teeth. See the pictures. !933 left, 1934 right.
2ndgeer is offline   Reply With Quote
Old 06-13-2021, 04:09 PM   #5
Reds34
Thank you guys! That is very informational. I will change the ad to reflect the correct year.
Red
Old 06-13-2021, 04:54 PM   #6
mercman from oz
mercman from oz's Avatar
1934 Ford Truck Grille - notice the Stainless Trim around the Grille Bars.
The 1933 Ford Truck Grilles didn't have this Stainless Trim.
Last edited by mercman from oz; 06-13-2021 at 05:01 PM. Reason: Description change
Old 06-13-2021, 04:58 PM   #7
mercman from oz
1933 Ford Grille, as posted by deuce lover.
Notice that it doesn't have the Stainless Trim around the Grille Bars that was added for 1934.
Old 06-14-2021, 08:23 AM   #8
uncle buck
uncle buck's Avatar
That is helpful information guys. Can you please post the differences between a '32 commercial and '33 also?
uncle buck is offline   Reply With Quote
Old 06-14-2021, 10:30 AM   #9
DavidG
DavidG's Avatar
The '32 is similar to the '33 regarding the stamped raised areas surrounding the Ford oval and opening for the radiator neck, but not as deep given that it is mounted completely vertical rather than sloped. The oval opening for the hand crank extension is smaller and it only has one hole for the hand crank extension through the lower back panel unlike the '33-'34s which have two holes. That last characteristic makes it easy to distinguish them unless the back panel has rusted away or been otherwise removed.
DavidG is online now   Reply With Quote
Old 06-16-2021, 08:22 AM   #10
uncle buck
uncle buck's Avatar
Thanks David. That crank hole detail is easy to remember
Old 06-16-2021, 09:01 AM   #11
DavidG
DavidG's Avatar
You're welcome.
Old 06-16-2021, 10:41 AM   #12
Lawson Cox
Lawson Cox's Avatar
Well, I see I was wrong again. Often wrong, but never in doubt. (LOL).
Old 06-22-2021, 06:38 PM   #13
Reds34
So,
What year is this? Obviously the bottom is gone, so I can't go by the crank hole(s). I think it may be a '33?
Thank you.
Red
Old 06-22-2021, 06:44 PM   #14
al's28/33
al's28/33's Avatar
yes that's a '33 shell.
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
