11-28-2021, 05:25 AM | #1 |
Decided against turn signals.....what about this idea?
There are many model A owners that swear by their add-on turn signals, and I can see where they would be a great addition to a daily driver......but.....I really hate the look of them. I want my model A to have the look of the old days.
Sooooo, what about this idea: Mini Strobe Beacon Safety Flasher Warning Light / Magnetic Base Mount https://www.ebay.com/itm/154223944800?var=454334244660 This is a hand-held red strobe light. It would likely be seen and recognized by those who are not used to seeing anyone using hand signals. It blinks, and is red, similar to modern turn signals. It has a magnetic base that might be handy for keeping it somewhere in the driver's area, when not being used. Well, yes......you still have to roll down your window!.....but your model A retains the old-timey look that I'm hoping to preserve. What do you think of this? |
11-28-2021, 06:08 AM | #2 |
Re: Decided against turn signals.....what about this idea?
Would you stick it out the passenger window for right turns?
11-28-2021, 06:17 AM | #3 |
No.....use like you would normally do for regular hand turn signals.
11-28-2021, 06:24 AM | #4 |
Not for me…..
Seems like just enhanced arm signals from long ago. Btw, I’ve not seen an arm signal for turns out a drivers window in 25 years. Now I’ve seen a few “finger signals” fairly often!! |
11-28-2021, 06:28 AM | #5 |
Do you have added turn signals on your model A?
11-28-2021, 06:37 AM | #6 |
I could easily install one of the turn signal kits on my model A.....but, like I said, they just look out of place. |
11-28-2021, 07:21 AM | #7 |
With all due respect if turn signals look out of place, this will look ridiculous. People will think a kid is playing a game.
11-28-2021, 06:48 AM | #8 |
I bought a pair of old turn signal lights with the arrow shaped lenses I plan to restore and use on front and add original style tail light on right for my AA project.
11-28-2021, 07:35 AM | #9 |
Beacuse holding a flashing light in your hand then trying to put it somewhere when turning is safe.....
Have a search for mini LED lights, plenty of super small versions available now custom bike builders use. I have these on one of my HDs, you wouldnt notice them on a Model A until they get turned on. https://roadsiderepairshop.com/produ...-dyna-xl-black
Looking for an unrestored 33 34 3W or 5W coupe. Thanks Last edited by panhead_pete; 11-28-2021 at 07:42 AM. |
11-28-2021, 07:50 AM | #10 |
What is not to like about turn signals ? You don't like the switch ?
There is no need to change or add anything to the outside of the vehicle. |
11-28-2021, 07:55 AM | #11 |
Obviously, You make a very valid point!
11-28-2021, 08:23 AM | #12 |
I use the tail lights and cowl lights for turn signals, so there is no exterior change in appearance from the original Model "A".
Bob Bidonde |
11-28-2021, 05:35 PM | #13 | |
They are activated by spring loaded toggle switch under the dash rail and self cancel after 15 seconds unless you have the brake on. The controller is hidden behind the left kick panel so no hardware or wiring is visible. http://www.turnswitch.com/ Last edited by GPierce; 11-28-2021 at 06:31 PM. |
11-28-2021, 09:21 AM | #14 |
I have added turn signals on my '29 Tudor. Sitting in the driver's seat, you can see the controller on the side of the steering column. There is NOTHING on the outside of the car that isn't on the original, all turn signal lights are part of the stock-looking lights of the car.
Many use the cowl lights. I use the second bulb (double contact) in the headlight can. And, of course, the tail lights in the back. Properly done, there is nothing to "hate the look of them". |
11-28-2021, 09:32 AM | #15 |
Delete
11-28-2021, 05:49 PM | #16 | |
Old Guy, I don't like the looks of turn signals either, esspecially those GM side marker looking lights that mount between the bumper bars. Or the switch hanging off of the steering column. I have a DPDT toggle switch under the dash rail and use small 2" "bullet" lights on the rear that resemble the headlight shells. Last edited by Y-Blockhead; 11-28-2021 at 06:09 PM. |
11-28-2021, 09:37 AM | #17 |
“There are many model A owners that swear by their add-on turn signals, and I can see where they would be a great addition to a daily driver......but.....I really hate the look of them. I want my model A to have the look of the old days.”
I understand this sentiment completely, and for years did not add a passenger-side tail/brake light or turn signals and kept my car completely stock to preserve its original look. I also drove the car about 100 miles per year. However, after starting to drive my Model A in daily traffic several years ago, I quickly realized most drivers today don’t recognize hand signals and aren’t attentive enough to recognize a single tail/brake light. Sooo….to avoid being rear-ended and be able to drive safely in modern traffic, I did add a passenger-side light and added LogoLites LED turn signals. I also upgraded all lighting except cowl light to LEDs. I’m now much more confident that other drivers will see me and have put about 2000 incident-free miles on the car this past year. Good luck with whatever decision you make. Jim Last edited by Conaway2; 11-28-2021 at 09:45 AM. |
11-28-2021, 09:40 AM | #18 |
Well, Old31 that was kinda harsh don't ya think? People come here to get help, and discuss ideas. Just because someone has a different idea, or opinion doesn't make it wrong.
11-28-2021, 12:08 PM | #19 |
Need to be careful before clicking submit. I was chastised for my reply to someone who took issue with one of my posts. I wasn't being disrespectful to the person--just honest. Feel lucky I wasn't banned. Be nice, everyone needs to feel welcome on this blog.
11-28-2021, 12:16 PM | #20 | |
The strobe is on the way. Looking forward to trying it out! |
