08-04-2022, 10:59 AM | #1 |
Coker tires
Hello gang. I have a question about Coker tube type tires. I bought a new set along with the tubes rated @32psi. The problem is they seem to be losing air. I've tightened the tube stems but nothing seems to work. Does anyone know anything about this?
08-04-2022, 11:04 AM | #2 |
Re: Coker tires
Cheap rubber in the tubes. It is my understanding that Bratton's had a run of good tubes made.
Charlie Stephens |
08-04-2022, 11:18 AM | #3 |
Re: Coker tires
Check the valve stems for leaks. I used a clear plastic tube filled with water to check for a slow leak.
08-05-2022, 05:24 AM | #4 |
Re: Coker tires
08-05-2022, 08:56 AM | #5 |
Re: Coker tires
Some people run motorcycle tubes.................
Paul in CT |
08-05-2022, 11:15 AM | #6 |
Re: Coker tires
08-05-2022, 11:18 AM | #7 |
Re: Coker tires
I’m also looking to replace my tires and tubes. Tam’s didn’t seem to know about the “Cheap Tubes” on the market. I don’t want to buy junk especially expensive junk! So maybe I’ll call Brattons
08-05-2022, 11:23 AM | #8 |
Re: Coker tires
Call Bratton's, but they had a lot of problems with their tubes used with radials. They will be straight with you, regardless.
1924 Model T Coupe 1928 Model A Roadster 1930 Model A Town Sedan 1939 Deluxe Fordor 1945 pickup 1951 Custom convertible |
08-05-2022, 08:59 PM | #9 |
Re: Coker tires
08-05-2022, 09:44 PM | #10 |
Re: Coker tires
What's the matter with the tubes in the tires on your car right now?
08-06-2022, 01:16 AM | #11 |
Re: Coker tires
I'm on my third set of tires and still running with my forty year old tubes.
08-06-2022, 06:32 AM | #12 |
Re: Coker tires
Coker have a range of tubes from cheap to incredibly expensive radial rated and weigh a ton. Which ones were they?
08-06-2022, 09:29 AM | #13 |
Re: Coker tires
In the latest Paul Shinn video he talked about a guy he knew that had just put a new set of tubes in his Model A tires, drove maybe a hundred miles and had a blow out.
Turns out the rubber valve stem blew off of the inner tube. Talk about cheap junk, geez. Makes having a 1969 era muscle car w/ tubeless tires a lot easier to deal with than the junk inner tubes we are experiencing on the older cars |
08-06-2022, 09:34 AM | #14 |
Re: Coker tires
What was the problem Bratton's had with their tubes in radial tires ?
08-06-2022, 10:22 AM | #15 |
Re: Coker tires
08-06-2022, 10:35 PM | #16 |
Re: Coker tires
Spittle works good, always right there when one needs it.
