Old 07-27-2019, 03:58 PM   #1
38coop
Default 49 Ford O.D. kickdown switch
When installing the kickdown switch , does it go all the way against the bottom of the floor board or is there a certain hight adjustment for underneath the gas pedal? Thanks.
38coop is offline   Reply With Quote
Old 07-27-2019, 04:19 PM   #2
40cpe
40cpe's Avatar
Default Re: 49 Ford O.D. kickdown switch
There might be a tech bulletin, but you want to adjust it so that it doesn't engage kickdown until the accelerator opens the carburetor completely. It might take two sets of eyes to watch the carburetor linkage and a continuity meter on the switch.
40cpe is offline   Reply With Quote
Old 07-27-2019, 07:07 PM   #3
Jersey Devil
Jersey Devil's Avatar
Tight to the floor board. Has been working fine for over 10 years. As stated above you need to make sure that the switch operates properly when pedal is depressed.
Hope this helps,
Tom
Jersey Devil is offline   Reply With Quote
