09-19-2017, 12:08 PM | #1 |
Steering Wheel Color
What is the correct color of black for a 1939 banjo steering wheel? I have seen them restored in a gloss black and I have seen them in a mat black. Trying to finish a high point car and need to know the correct black.
09-19-2017, 01:21 PM | #2 |
Re: Steering Wheel Color
The banjo steering wheel in a '39 deluxe is not painted black. The hub of the wheel was painted Zephyr Beige and the rim was painted Oyster Gray. This information comes from the Early Ford V-8 Club's '38-'39 book page #3-13. If you don't have this book you should buy it if you intend to restore a '39 Ford as a high point car.
09-19-2017, 02:49 PM | #3 |
TJ is correct. Here are photos of two 1939 Deluxe models I've restored. Rest assured these are correct and high point cars.
09-19-2017, 05:25 PM | #4 | |
09-19-2017, 08:10 PM | #5 | |
ALL of my restorations can be driven with confidence. When I get a bit further on the current project, I will post more photos of what I do in places no one will ever see again. Bottom line? I don't skimp...
"I can explain it for you. However, I can't understand it for you". Last edited by Kube; 09-20-2017 at 07:24 AM. |
09-19-2017, 09:06 PM | #6 |
09-20-2017, 09:19 AM | #7 |
You'll be happy with the '38-'39 book. It will give you some great info on your project. Good luck on your restoration. '39 Deluxes are beautiful cars.
03-29-2023, 12:49 PM | #8 |
Somewhat color related, is the metal frame for a 1939 convertible also Oyster Gray? Can someone (Kube's I'm guessing) provide the paint code for Oyster Gray?
