Old 12-04-2022, 02:21 AM   #1
fiddy6
Default Aerostar spring isolaters.
I know this is probably best left for the H.A.M.B but I searched and couldn't find direct part numbers.
Who has used aerostar springs with isolators and if so, what parts did you use and where did you get them?
I've ordered some Moog CC850's and some pancake bump stops.
fiddy6 is offline   Reply With Quote
Old 12-04-2022, 05:25 AM   #2
KULTULZ
KULTULZ's Avatar
Question Re: Aerostar spring isolaters.
I think this is what you are looking for -
https://teamenergysuspension.com/ene...ing-isolators/
What are you working on?
We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ...
KULTULZ is offline   Reply With Quote
Old 12-04-2022, 01:30 PM   #3
fiddy6
Default Re: Aerostar spring isolaters.
Thanks.
It's a 56 Victoria.
Old 12-04-2022, 01:55 PM   #4
miker98038
miker98038's Avatar
This goes back over 10 years, and that’s a while to remember. When I put the Aerostar springs in my bird I thought I might need isolators. Seems to me I found a Mustang site that sold them (in the nominal 4” size) in various thicknesses for tuning ride height with lowered springs. The relationships of the spring/arm length/spindle would be a little different, but probably not a lot. Might give some informational to get you closer.
If you know what thickness you want, K’s info should get it done.
Edit. I just saw your picture of a 56 on another post. Great looking ride.
miker98038 is offline   Reply With Quote
Old 12-04-2022, 03:20 PM   #5
KULTULZ
KULTULZ's Avatar
Arrow Re: Aerostar spring isolaters.
Well, they have different style(s) for use as an isolator, insulator and/or spacer, you just need to figure which way you wanna go.
I think this is what you are after to just insulate the lower coil from the arm to prevent any noises. They have upper isolators also.
- Ramped Coil Spring Isolator Set -
Coil-overs is another method that will ease trim height selection and stiffness -
Old 12-04-2022, 11:46 PM   #6
fiddy6
Great info. Thanks.
I'm interested mainly in the top isolator... I guess my main concern is probably that it will be too low and I will want pad it a bit.
My factory isolators are not in great shape so I'll need some replacement.
Old 12-04-2022, 11:48 PM   #7
fiddy6
Yes Mike.
I love my 56. It great looking. The front could be a bit lower and I'm looking for the progressive spring to improve handling a little.
Old 12-04-2022, 11:55 PM   #8
fiddy6
It's got a 312 and medium case fordo from a t bird. The body is completely rust free (now). I've rebuilt the front end and everything but the motor.
I'm looking to customize it a little with suspension and classic wheels.
Just a cool cruiser.
Old 12-05-2022, 01:58 AM   #9
KULTULZ
KULTULZ's Avatar
If you just want OEM STYLE uppers - https://cgfordparts.com/coil-spring-...-b8a-5415.html
Old 12-05-2022, 08:06 AM   #10
bobss396
bobss396's Avatar
My car was way too low with the CC850 springs, looked nice but with the 215/75-15 tires they scraped too much. So I took a coil off the OG ones and put them back in. The disc conversion also shoots out the wheels a bit. I would consider putting the CC850s back in, and would need to get something off the Energy Suspension site.
bobss396 is offline   Reply With Quote
Old 12-05-2022, 08:30 AM   #11
Hot Rod Reverend
Hot Rod Reverend's Avatar
this blog post may help you as well - I too installed the CC850's and ended up raising the height with 1" spacers.
https://www.hotrodreverend.com/post/...ng-on-the-ford
Lancaster, California
Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan!
Hot Rod Reverend is offline   Reply With Quote
Old 12-05-2022, 01:48 PM   #12
fiddy6
Thanks Daniel. I've gone and ordered the same spacers
Old 12-06-2022, 11:05 AM   #13
Adriatic Machine
I used Aerostar coils in my 59’ Rancho, no isolators. Front end sits just right and rides great
Adriatic Machine is offline   Reply With Quote
Old 12-06-2022, 01:26 PM   #14
Hot Rod Reverend
No problem - I did like the "lowered look" but I kept getting some tire rub up front on extreme lock-to-lock turns. It wasn't a big deal but I am pretty happy with how she handles and rides.
Old 12-08-2022, 09:06 PM   #15
mercman from oz
mercman from oz's Avatar
Your 1956 Ford Fairlane Victoria looks great as it is !
Old 01-03-2023, 11:24 PM   #16
fiddy6
So I finally got a chance to put it all together.
Bare in mind that I like a neutral stance. Not ready looking for really low.
Moog CC850 springs + Mr Gasket 1285 spring isolators.
I stayed with the stock lower bump stop as there seems to be plenty of travel.
Drives much better with the progressive spring. I think the isolators quiet things down alot.
Old 01-07-2023, 09:10 AM   #17
bobss396
bobss396's Avatar
I may put the aerostars back in my car with the 1" spacers recommended here. Another groovy spring project.
Old 01-08-2023, 03:07 PM   #18
miker98038
miker98038's Avatar
It’s always nice to see a post with the final results and a satisfied owner. Great looking ride, thanks for putting this up.
Old 01-09-2023, 07:18 PM   #19
fiddy6
yeah it may settle out further but now I need to sort out the rear. My rear leafs have flattened out, I have no lowering blocks in the rear.
I been thinking about getting the springs re-arched and fitting lowering blocks to suit my tastes
or
fitting some air assisted shocks like gabriel highjackers and pumping them up to my tastes.
Any thoughts on those options?
Old 01-09-2023, 08:41 PM   #20
miker98038
miker98038's Avatar
I’ve got a friend with air shocks, but they’re only used to level a load in a Nomad wagon. I’ve never been big on them for regular use. (In his defense, they were on and new when he bought it).
Perfect solution would be someone who knew how to re arch the springs to where you want them, or a set made to do that. I’ve used blocks, but they’re not the perfect solution.
Looks pretty good the way it sits to me, but what’s important is how it looks to you.
