Old 04-24-2024, 08:15 PM   #1
v8fordman
v8fordman's Avatar
Default Side Water Outlet
Just came across this and was wondering if anyone had ever seen or had one like it? It has Ford script and the diamond cast in it.
v8fordman is offline   Reply With Quote
Old 04-24-2024, 08:52 PM   #2
Bob C
Default Re: Side Water Outlet
I think it's for a Model T.
Old 04-25-2024, 09:10 AM   #3
katy
katy's Avatar
Ditto
BTW, It's a water INLET, not An OUTLET, which is on the top of the head.
Old 04-26-2024, 10:10 PM   #4
CWPASADENA
CWPASADENA's Avatar
The "Diamond" you refer to is the Ford foundry mark. If you look carefully, there is this mark on a lot of the castings made by Ford.
CWPASADENA is offline   Reply With Quote
Old 04-27-2024, 11:36 AM   #5
Jim Brierley
The diamond is a genuine Ford part but cast by an outside foundry. That mark can be found on many Ford parts.
Old 04-28-2024, 06:29 PM   #6
Synchro909
Synchro909's Avatar
Funniest looking diamond I have ever seen. Looks like a triangle to me.
Old 04-28-2024, 07:02 PM   #7
Terry Burtz, Calif
Arnold, I agree that it is a triangle and an original foundry mark.
Original Ford Model A cylinder heads manufactured during production had either a straight line, 45 degree line, or a triangle on the top of the head between the two upper water pump mounting studs. This foundry mark was used for QA (Quality Assurance) to identify the source of discrepant parts.
Cylinder heads manufactured later and sold at Ford dealers as replacement parts were marked differently.
Terry Burtz, Calif is offline   Reply With Quote
Old 04-28-2024, 07:46 PM   #8
mcgarrett
I agree with Bob C especially because it is missing the threaded boss for the conduit clip.
