Old 11-29-2017, 04:30 PM   #1
Ian1932
Ian1932's Avatar
Default Paint formulas ??
I found this sheet(s) does anyone know if i can take this to get paint mixed. The colors i want o use "they" cant find the color. I normally get paint from napa auto parts. Im looking for a base coat clear coat system. I normally have a paint code from a more modern car...this is a little different than what im used too...
Ian1932 is offline   Reply With Quote
Old 11-29-2017, 04:34 PM   #2
JSeery
JSeery's Avatar
Default Re: Paint formulas ??
Doubt older codes will be of much value.
Old 11-29-2017, 04:52 PM   #3
jehagado
PPG and dupont have solid color books and card decks with all the shades.
You need to color match an original paint part to the color book, old codes are useless.
jehagado is offline   Reply With Quote
Old 11-29-2017, 05:13 PM   #4
Tony, NY
You can try calling the PPG tech line (I did for Washington Blue) and see what late model color is the same. I was given a color off of an 1987 Isuzu Trooper.
Tony, NY is offline   Reply With Quote
Old 11-29-2017, 05:29 PM   #5
Henry Hopper
Henry Hopper's Avatar
http://paintref.com/cgi-bin/colorcod...936&manuf=Ford
Try this page...they list the colours and the codes.
My brother just had his 55 Chevy repainted the factory colour...he took a piece of trim with the original paint still on it and the paint supplier used their scanning machine and matched it perfectly.Could be worth asking if they could do likewise at your suppliers.
Henry Hopper is offline   Reply With Quote
Old 11-29-2017, 05:31 PM   #6
deuce_roadster
deuce_roadster's Avatar
The tinting bases that are displayed on your sheets have no doubt been changed and they will be of little use.
Old 11-29-2017, 05:32 PM   #7
Ian1932
Ian1932's Avatar
I just talked to PPG. They said i can get acrylic lacquer or single stage urethane. I guess the urethane would be pretty good? I actually havent used a single stage urethane before but i have sprayed about everything else. The tech made it sound like the greatest thing ever...I guess thats what ill get...PPG dist. about 20 mins from home...Thanks!
Old 11-29-2017, 05:35 PM   #8
JSeery
JSeery's Avatar
That's interesting, your color codes must not have been that old!
Old 11-29-2017, 05:39 PM   #9
Ian1932
Ian1932's Avatar
winter leaf brown PPG code #986. They looked it up and found it. They did say they didnt have a formula for base / clear.
Old 11-29-2017, 05:54 PM   #10
mrtexas
mrtexas's Avatar
I get my paint from here for $125/gallon vs $500 per gallon for name brand single stage paint. They can match. Of course any local paint store can match as well. For around $60 you can get a quart and spray it out to see if you like it. I painted 4 cars so far with it. Their paint is likely Valspar just not PPG or Dupont. You will need around 2 gallons so the savings is substantial.
http://www.autocolorlibrary.com/
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
Old 11-29-2017, 05:55 PM   #11
rotorwrench
rotorwrench's Avatar
If its a Ditzler/PPG color code then they can get a close match. It boils down to how good the local paint supplier is to matching. I've know guys that can look at a color and know exactly how much of what to make a match. Old car parts fade too so some matches could be off a bit depending on the sample quality. Computer scan matches can be as much as a shade off due to the way the scanner reads the light brightness. It's not as good as the human eye is.
If they still have a single stage urethane like Concept, you would be likely happy with the results if you have experience spraying with a gun. The stuff is very much like the old Deltron Acrylic urethane and it is very forgiving in application. It has a shine like wet paint after it cures. I like that stuff but I've heard rumors that they are fixing to drop it. If it's something else, I couldn't tell you much about it. Take precautions with any urethane product, ie good respirator. The stuff can give you a chemical induced form of pneumonia that is hard to shake. God forbid if a person is allergic to it. I don't like breathing paint anyway and most folks share the sentiment.
Old 11-29-2017, 06:34 PM   #12
vulture
vulture's Avatar
Dither paint code info book for the 1928 -1936 I also have the later 1937 to 48. It has the color chips and paint codes so let me know how I can help with color or code
Wanted Roadster Pick up thank you COLOR]
vulture is offline   Reply With Quote
Old 11-29-2017, 06:44 PM   #13
vulture
vulture's Avatar
Sorry don't know how to post more then one pic and this is 28-36 colors
Old 11-29-2017, 06:44 PM   #14
vulture
vulture's Avatar
Codes for one quart
Old 11-29-2017, 06:55 PM   #15
Ian1932
Ian1932's Avatar
Originally Posted by vulture View Post
Codes for one quart
I guess i can get the color from PPG in acrylic lacquer or single stage urethane.
What i really want is to use martin senior base coat & clear coat ACME Finish1 FC740. Im my mind this is the most forgiving system i have ever used! This system works so well in less than favorable conditions like, high or low humidity, or very cold or very hot. Thats what i really would like to get, but, it sounds like i just cant get it unless the guys just eyeball it or pick a swatch thats close...
Old 11-29-2017, 07:09 PM   #16
vulture
vulture's Avatar
I am unsure if I have a old old Martin catalog most of my stuff is OLD shit. I am sure they can scan a chip with the gun and get you a new formula . I am sure it can't be for paint match but a full coat it would be darn close..
Old 11-29-2017, 08:13 PM   #17
Tony, NY
I know they're dropping the acrylic enamel. Doubt the single stage urethane would be dropped. But who knows?
Old 11-30-2017, 07:13 AM   #18
Capn John
Capn John's Avatar
Great site!!!
+1
Capn John is offline   Reply With Quote
