Old 05-27-2017, 11:52 AM   #1
crock
crock's Avatar
Default Rear brake assembly
Can the rear brake shoes and emergency brake be completly assembled on the backing plate and installed on the car? It looks like the brake actuating arm may not go thru the hole in the support arm.
MY PROBLEM CHILD!
crock is offline   Reply With Quote
Old 05-27-2017, 11:56 AM   #2
A31Woody
A31Woody's Avatar
Default Re: Rear brake assembly
Yes. Remove the radius arms (both sides and up by the U joint), install backing plate(s) loosely with the two bolts that don't go through the radius arms, and then reinstall the radius arm / snug everything back up. Learned this on the barn after struggling for days trying to do it without removing the arms.
Our 1931 Station Wagon: Originally restored in 1962, redone in the early 1980's, brought back to life in 1997 and refreshed in 2016/2017. Check out the progress at a31woody.com
A31Woody is offline   Reply With Quote
Old 05-27-2017, 12:00 PM   #3
RawhideKid
As I just finished doing this I feel somewhat of an expert.
The answer to your question is YES, although I did remove the 2 springs from the e-brake band to allow some move ability.
First, remove the radius arms from both the rear flange and the front mount. Install the 2 SHORT bolts in the rear holes and snug them up with a long bolt in one of the front holes for alignment, then install the radius arm on that side, starting the bolt on the torque tube and tighten all 4 bolts on that side. I started with the drivers side. Then repeat on right side the same steps.
While you have the rear drum OFF, pull the service brake arm forward past the stop to expose the clevis hole and install the service brake rod, then return the lever to rear position. Sure makes it easier to install the clevis and cotter pin.
Before Walmart you had to buy a ticket to the fair to see a bearded lady!
RawhideKid is offline   Reply With Quote
