06-08-2018, 08:01 PM | #1 |
Babbiting
Can anyone recommend a “babbiter” in the Cleveland, Ohio area.
Thanks |
06-09-2018, 10:45 AM | #2 |
Re: Babbiting
No recommendation, as I have not needed this kind of service, but I did have in my info book a place in Ohio called Ron's! At least from their ad, they seemed to do anything and everything on engines and transmissions including babbit. You might try googling on Ron's, Ohio and babbit and see what shows up. My memory is Ron's did both babbit and inserts. Good luck on finding someone that meets your needs, and hope this helps.
06-09-2018, 12:39 PM | #3 |
Re: Babbiting
I am familiar with “Rons”.
unfortunately, he’s about a four hour drive from Cleveland. Looking at doing inserts at this point. Thanks ken |
06-09-2018, 05:29 PM | #4 |
Re: Babbiting
IMO, Inserts are the way to go. Last longer and love hard work. Clean oil, I’m told is important though.
06-09-2018, 03:22 PM | #5 |
Re: Babbiting
Be sure the machinist understands the process. Things like crank to cam center line distance and thrust bearing set up, for starters. You don't want to ruin a good block.
06-09-2018, 04:22 PM | #6 |
Re: Babbiting
06-09-2018, 04:25 PM | #7 |
Re: Babbiting
Rally 1:
Kevin Pruss is in eastern Ohio. 1-330-774-7130. Good reports from my friends. Vic |
