#1 |
I want to replace the spring bushings in my 48 car, it’s been 25 years or so and I imagine there has been a lot of changes in the part. Suggestion for the best would be appreciated.
Thanks, Rick |
#2 |
Check out CW MOSS;
https://cwmoss.com/search?q=spring+bushings |
#3 |
Will do thanks 19Forty
#4 |
Do not just install them in any orientation. They should be installed at the working angle.
#5 |
Andy is correct. 45 degrees is the desired angle. The photo below is a 40 Ford reversed eye spring with shackles at 45 degrees.
#6 |
#7 |
#8 |
#9 |
Thanks guys for all the feed back , does any one know where to get ones mentioned in post 7 thanks again to all here who offered their help.
Rick |
#10 |
McMaster_Carr. https://www.mcmaster.com/nylon-6/wea...t-nylon-tubes/
#11 |
Thanks Bob
#12 |
If you have a lathe, you can make your own out of brass. However, DELRIN is less expensive and will work great.These homemade shackles and bushings are are 50 years old.
#13 |
Thanks 19forty, don’t have a lath so I will have find them already made
#14 |
I tried a few "plastic" bushings. I can't tell one from the other, but they all squeaked. I finally went to impregnated bronze flanged bushing or flanged bearing like 19forty made. Available in different sizes from your bearing store.
#15 | |
![]() Quote:
Delrin won't. Like any bearing, it helps life if you lube them once in awhile also. |
#16 |
#17 |
McMaster-Carr supply- oil inbedded flanged nylon bushings
#18 |
Thanks to all for advice and assistance
#19 |
3rd gen sell both original and modern style show car original daily or regular driver defiantly modern like most things its your choice
Thread Tools | |
Display Modes | |
