02-21-2022, 08:44 AM | #1201 |
Re: 1932 The Deuce, Dually, Dump Truck
Gary, Folks,
I agree with the black fasteners for sure. I already had most of the saw marks removed by the planer, (sorry) The saw marks on the vertical is from me whittling these to the correct width with my borrowed table saw. I dont at all call this a restoration, as I know what it takes to do that, and this old brain just is not going there. Want it functional and safe and in its work clothes. That's about it. I do still have the original side boards and head board for the truck. Maybe at some point they will go back on? The machined "B" block should be ready for me in about 6 weeks. I would like to have it changed out by June 1 2022. Off to work on maple syrup projects. Taps are in place, temp is moving to mid 40's. Might have sap to boil tomorrow?? Hope things are good in Ford Land! Regards, Chris
1932 AAB Truck 1953 Ford Jubilee 2015 Ford F250 SuperCrew Lots of Allis tractors Some Cub Cadets |
02-24-2022, 02:47 AM | #1202 |
I'm a fan of the rough cut boards. There is a place south of me that mills and have a junk pile I've been lucky to get from.
We are months away from tapping any trees here. Just dropped a ft of snow and it is -10 tonight. We do it as a hobby. Looking forward to all the posts. . Last edited by Tinker; 02-24-2022 at 02:59 AM. |
02-24-2022, 02:49 AM | #1203 |
Oh square nuts can be purchased at ace hardware. Bought some for my Mccormick deering. Just looked right.
02-24-2022, 08:34 AM | #1204 |
Tinker, Ford Folks,
A few off topic maple syrup related pictures. Ok there is a Ford in the process in a big way also: Sap pumping station on truck: Getting the evaporator arch ready for the first boil. Cleaning the drop flues and the grates: Cleaning the drop flue pan at the back of the arch: Lots of "getting ready" things: The first run of maple sap for 2022: Unloading the truck tank into bulk tank: Just starting to boil: We have gathered about 600 gallons of sap. Boiled it down to about 60 gallons, and it is now much sweeter. It will rest in the pans waiting till next week to get additional sap to finish this to syrup. That should make about 12 gallons of syrup. Regards Chris
02-24-2022, 12:15 PM | #1205 |
Folks,
I even recruit other Ford Folks too! John, (42 Deluxe) firing the 3x10 antique King evaporator: Smoke stack end of the rig: Syrup boiling: Hope things are good in Ford Land! Regards, Chris
02-24-2022, 01:02 PM | #1206 |
02-24-2022, 09:32 PM | #1207 |
Chris you have some serious equipment there, better keep that shop under 24 hour surveillance. When do ever have time to sleep ?????
…...…… thanks (as always) for satisfying our curious minds about you!!!!
1928 "A" Phaeton (mid year with many early features) 1933 "V8" Closed-Cab Pickup Truck (originally a Model B, 4 Cylinder dating to May, 1933)
02-25-2022, 03:23 PM | #1208 |
Al, Folks,
Sleeping well and often too! Just makes it look like I am doing something! The atr of illusion! Thanks for checking in on me! Hope things are good in Ford land! ?????? Should I buy a mid 80's Ford truck when I have so many other things I should do in life?? Ok you dont have to answer that! ?????? Regards, Chris
02-25-2022, 04:06 PM | #1209 |
Chris,
When you run out of something to do I found another one for you!?! Like you really need something else to do, right? Ted |
02-25-2022, 08:42 PM | #1210 |
Chris, with that hot fire goiung with the syrup operation, I would take a piece of coat hanger wire and run it through a handful of Ace Hdw squate nuts and set them on the coals. In the morning they will have '1932' written all over them,.....
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
02-25-2022, 09:37 PM | #1211 |
Great find. the recommended 50% acetone and Marvel Midstory oil. soak it be patient it will take quite a while. I just freed up a flathead sitting for 56 years.
02-26-2022, 08:04 AM | #1212 |
Thanks guys for the hints and wake up!
I don't think I will be getting another truck project but that one could be brought back! Moving big tool box today for mike the mechanic grandson. He starts a new job with local Buick, gmc dealer! Regards, Chris
02-26-2022, 05:02 PM | #1213 |
Folks,
Resting. Moved Gradnson Mike to his new job today, He trusted me moving his very expensive tool box with my old stuff: We winched in on with a steel plate on the ramps: Used the jib to unload the sap tank and set the fifth wheel: Picture from last night when we brought the trailer in the shop with a inch of ice on the deck. All nice and clear for the move today: The 32 truck gets a break. Regards, Chris
02-26-2022, 06:09 PM | #1214 |
A garden hose inside the shop...thats something I have always dreamed about
02-26-2022, 07:04 PM | #1215 |
cas3, Folks,
The shop is pretty much still a dream to me. I only waited about 30 years for it! Yes I plumbed in a water supply outlets for a washer, in the bay where the F250 is parked. I rinse down the truck when ever it needs it. Hot water is supplied with the propane boiler. Not as much quantity as a 40 gal tank but plenty to rinse down a truck. Here was the rough in with the hose reel: It has been a really nice addition to the shop. I use it a lot. The hose reel is really sweet. It is all steel, coated, and pivots out away from the wall to make bringing the hose back in very slick. I really need one in the kitchen area. but this one is pretty close by. Regards, Chris
02-26-2022, 08:35 PM | #1216 |
that 'tired' '34 BB has the Timken rear diff, first yr, and a big seller for Ford. Newc
02-26-2022, 10:53 PM | #1217 |
Chris since you have water inside your shop, do you have that area concrete sloped to a drain too ???? I would think you'd prefer to keep the inside dry and not have standing water anywhere.
02-26-2022, 11:59 PM | #1218 |
I was wondering the same thing. A floor drain would be ideal, lest one would have to floor squeegee the over flow out side. I also recall in a previous post the radiant floor heat. A dream for a shop.
02-27-2022, 10:47 AM | #1219 |
Guys,
Yes three floor drains, with good slope to the drains too. Floor dries in a couple hours. Thanks for the compliments. Tried to think of most needs for a old kid and his toys! We wait for warmer days so the sap will run. Regards, Chris
02-27-2022, 12:15 PM | #1220 |
For me it would be the toilet.... The 75 yards up to the house is, Oh, never mind. And Chris, the hot water wash down system is great where you have road salt.
