Old 04-13-2012, 12:37 PM   #1
1952henry
1952henry's Avatar
Default T'Bird 6V maifold/carb/air cleaner value
What's a ballpark value for a complete T'Bird 6V setup, both original and restored condition?
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 04-13-2012, 12:45 PM   #2
Ole Don
Ole Don's Avatar
Default Re: T'Bird 6V setup value
If you are talking of just a regulator and generator, I would think not much as they must be the same as the passenger and light truck of that year.
Ole Don is offline   Reply With Quote
Old 04-13-2012, 12:51 PM   #3
1952henry
1952henry's Avatar
I'm talking about the factory 3X2 setup. I should have been more specific!
Old 04-13-2012, 06:08 PM   #4
Ole Don
Ole Don's Avatar
Default Re: T'Bird 6V maifold/carb/air cleaner value
I would think the guys on the FE forum would guess better than us Y block and 302 guys. It would help if you could post a picture to show condition and how complete it is.
Old 04-13-2012, 06:45 PM   #5
Y-Blockhead
Y-Blockhead's Avatar
Ole Don, isn't a FE a "Late V8 (1954+)" as the name of the heading sez?? Not just for "us Y block and 302 guys". There doesn't seem to be a FE Specific Forum on the Barn.
There I go, making friends again...
Old 04-13-2012, 07:39 PM   #6
1952henry
1952henry's Avatar
I don't have pictures as of yet. I just thought someone on this forum would have some knowledge of them
Old 04-13-2012, 07:44 PM   #7
streetdreams
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
Somewhere around $1500 - $2000, maybe more, if it's complete with original carbs, air cleaner, fuel log and linkage. Since it's T-Bird specific, you've got a limited, but captive market.
streetdreams is offline   Reply With Quote
Old 04-13-2012, 09:01 PM   #8
parklane
parklane's Avatar
I sold one about 1990 that was complete with linkage, air breather, and fuel log for $650. and the carbs needed a rebuild.
If brains were wire, some couldn't short circuit a firefly
parklane is offline   Reply With Quote
Old 04-14-2012, 03:39 AM   #9
1952henry
1952henry's Avatar
thanks!
Old 04-14-2012, 06:59 AM   #10
ken ct
That was funny Owen,im a FH guy and even i knew you were talking about a 3x2 setup LOL LOL. Its worth some bucks. ken ct.
ken ct is offline   Reply With Quote
Old 04-14-2012, 02:40 PM   #11
JeffB2
JeffB2's Avatar
This would be the place to find out: http://www.network54.com/Forum/74182/
JeffB2 is offline   Reply With Quote
Old 04-14-2012, 04:00 PM   #12
28RPU
28RPU's Avatar
I think this sounds about right. Last one I had I sold for 300 bucks so you know that was a long time ago. But I only paid 35 bucks for it. They used to be everywhere because no one knew how to tune them and swapped them out for single four barrels.
Don’t pick a fight with an old man. If he is too old to fight, he’ll just kill you.
28RPU is offline   Reply With Quote
Old 04-14-2012, 06:30 PM   #13
streetdreams
Be careful not to confuse the two types of Ford factory tri-power for the FE motors. The more common setup is from the FE Galaxies and Mercurys, '61 - '63. The carb pads on the intake are stepped to allow for the angled engine installation. The Thunderbird setup has an intake with carb pads at the same height, as engine installation angle in a '61 - '63 Bird is level.
Old 04-16-2012, 08:43 AM   #14
1952henry
1952henry's Avatar
This is a 'Bird setup.
Old 04-16-2012, 05:16 PM   #15
streetdreams
1952, understood. I was talking to 28RPU. The Ford setups are fairly common. The TBird setup you have is much rarer.
Old 04-17-2012, 02:45 PM   #16
1952henry
1952henry's Avatar
Thanks again for the input, fellas!
