Old 03-03-2021, 10:06 PM   #1
Smitty
Smitty's Avatar
Default 51 Ford 6cyl PCV System
Hi All,
Where the PCV valve enters the tappet cover on the 226 engine there is a rubber plug. Anyone have a good replacement solution for this plug or a beter setup?
Thanks, Steve
Smitty is offline   Reply With Quote
Old 03-04-2021, 03:25 AM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 51 Ford 6cyl PCV System
Originally Posted by Smitty View Post
Hi All,
Thanks, Steve
Steve....This should be a piece of cake. DORMAN has a bazillion different PCV grommets in their line-up. They can be ordered at most major auto parts stores if they are not in stock. Click the link below to see what I mean. Hope this helps ya! We've used their stuff for our flathead/PCV adaptations. DD
https://www.dormanproducts.com/c-544-pcv-grommets.aspx
Click Links Below __
T5 W/TORQUE TUBE
Old 03-04-2021, 06:17 AM   #3
Smitty
Smitty's Avatar
DD,
Thanks, I will head down to our local NAPA this morning.
Thanks, Steve
Old 03-04-2021, 12:09 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
DD,
Thanks, Steve
Let's hear how this turns-out! DD
T5 W/TORQUE TUBE
