11-12-2015, 12:51 PM | #1 |
1942 Merc Flathead - First Fire Video
I know there are a lot of flathead guys on this site, thought you might enjoy the compilation video I made of the first firing of my 1942 full-race Merc flathead. I cover all the technical details over on the HAMB.
Engine Specs: - 284 Cubes, 4 1/8 stroke, 3 5/16 bore - Rods: 21A full-floaters - Custom roller cam - .420 lift and 320 degrees duration at .010 - Valves: 1.72" intakes and 1.6" exhausts - Custom Ross pistons, metric TotalSeal rings - 100% full-flow oiling system - Heavily ported and relieved - Intake: Original Eddie Meyer, ported 10 ways to Sunday - Heads: Navarro . . . thanks to my old friend Barney - Performance Coatings: pistons, valves, bearings - And a lot of other detailed and goofy stuff . . . Enjoy: https://youtu.be/QtagrmClLQ8 Dale |
11-12-2015, 01:41 PM | #2 |
Re: 1942 Merc Flathead - First Fire Video
Dale, Watched that over on the HAMB site last nite. Sure sounds mean. I hope that mine comes out half that good looking & sounding. Bill
11-12-2015, 10:11 PM | #3 |
Congratulations! That engine turned out awesome.
11-13-2015, 08:37 AM | #4 | |
Best of luck - if I can help you in any way, just ping me! Dale Last edited by Bored&Stroked; 11-13-2015 at 12:48 PM. |
11-13-2015, 08:38 AM | #5 |
11-13-2015, 09:22 AM | #6 |
11-13-2015, 11:49 AM | #7 |
Nice--you spent some money on lifters and machine work for that roller cam!
11-13-2015, 12:33 PM | #8 | |
11-13-2015, 01:48 PM | #9 |
Dale, 320 at 0.010!!! Damn! That's some cam in that thar mill.
Martin. |
11-13-2015, 05:18 PM | #10 |
Nice!! I like the fact that you used the full floating rods..I believe when set up right they will out perform insert bearings.
11-13-2015, 11:43 PM | #11 |
Sure sounds sweet! What are you running for exhaust? Sounds like headers and no mufflers.
11-14-2015, 09:07 AM | #12 |
Just headers at the moment - haven't had time to weld up the exhaust. I'm probably going to try straight pipes that exit if front of the rear wheels . . . see if I can get away with that for awhile! Sounds like fun to me.
