Old 03-04-2021, 11:07 AM   #1
Magoo2
Default Front end alignment question
I’m in the process of aligning the front end of my 31 CCPU. I’m using a toe in gauge, basically a spring loaded bar that wedges between the tires. After positioning and zeroing the gauge, I pull the truck forward the gauge moves to a toe out reading at the lowest point then moves to a toe in reading at the rear most position. Is that normal?
Magoo2 is offline   Reply With Quote
Old 03-04-2021, 11:42 AM   #2
paboot
paboot's Avatar
Default Re: Front end alignment question
Hey Magoo2, here is a youtube video from Paul Shinn. He explains what needs to be done. Did mine like he said, work out great.
Good luck, PaulB
https://youtu.be/LdNb-NU9vf0
paboot is offline   Reply With Quote
Old 03-04-2021, 11:48 AM   #3
Bob C
It is normal because of the camber, the wheels are out at the top
and in at the bottom.
Old 03-04-2021, 11:54 AM   #4
frank55a
Sounds like you ae trying to compare apples and oranges. Toe in/out is a horizontal reading i.e., front to back at the same distance off the floor. Toe in the front reading is less than the rear reading.
The tires have a slight inward vertical angle from top to bottom. This is fixed i.e., King pin, there is no way to change this except to bend the axel.
Sounds like you are trying to compare a vertical reading to a horizontal reading.
Should be read at the front most position compare to the rear most position.
frank55a is offline   Reply With Quote
Old 03-04-2021, 12:51 PM   #5
Brentwood Bob
Paul Schinn makes it simple.
Brentwood Bob is offline   Reply With Quote
Old 03-04-2021, 01:16 PM   #6
McMimmcs
McMimmcs's Avatar
Right or wrong we followed his suggestions and it turned out fine.
Old 03-05-2021, 01:34 AM   #7
PotvinV8
PotvinV8's Avatar
Use a tape measure, get it close and take it for a drive. Adjust as necessary. You can measure the distance between two similar points on the tires and get it as close as it needs to be without a "toe-in gauge".
PotvinV8 is offline   Reply With Quote
Old 03-05-2021, 07:29 AM   #8
nkaminar
nkaminar's Avatar
If you change the caster by repairing or adjusting the ball at the end of the front wishbone, you will change the toe in. If you do any changes to the front end, the toe in should be checked last.
Old 03-05-2021, 09:54 AM   #9
KenBolton
An old mechanic taught me that after you get toe in where you want it to roll the vehicle forward and backwards a good distance so the front end will settle in. It can make a difference. Or, as a previous post, drive it and check again.
KenBolton is offline   Reply With Quote
Old 03-05-2021, 10:40 AM   #10
BillCook
Send a message via Yahoo to BillCook
We use to use a string for the Jeep’s in the army to adjust the toe .
BillCook is offline   Reply With Quote
Old 03-05-2021, 10:48 AM   #11
The Master Cylinder
The Master Cylinder's Avatar
Please explain, what did he do right or wrong?
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 03-05-2021, 12:02 PM   #12
katy
katy's Avatar
As the fronts of the wheels tend to push apart when the car is going forward, always check the toe-in after the vehicle has been moved forwards, never after the vehicle has been moved to the rear.
When checking toe-in I like to push the fronts of the wheels apart before measuring.
Old 03-06-2021, 11:37 AM   #13
Y-Blockhead
Y-Blockhead's Avatar
I would be interested in what Paul did incorrectly also. Maybe we can learn something??
Old 11-27-2023, 08:00 AM   #14
Rob Doe
I've been using the same tool as Paul. Our car goes straight down the road if not upset by common bumps, slopes and winds. Tire wear is even across the tread.
One thing not mentioned here yet: Make certain your wheel bearings are not loose.
I'm thinking that a wheel alignment on a modern vehicle with modern tools also aligns the front and rear wheels to each other, or at least checks it???
Our coupe had a shallow bend in a rear radius rod. When the rear end was disassembled for a cracked axle along the key way, the axle housing on the same side had a bent flange in one area of several degrees. I was told this happens when the car hits something like a curb with a major force. I could just barely see that the rear wheels were out of alignment all along, but didn't catch on until removing working on the rear end.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!"
Rob Doe is offline   Reply With Quote
Old 12-01-2023, 09:25 AM   #15
old31
This is an old thread but thats ok, people can still learn from it.
I have been doing my alignments the exact same way that Paul showed in his video and that has always worked out well for me.
old31 is offline   Reply With Quote
Old 12-01-2023, 08:16 PM   #16
katy
katy's Avatar
Also make sure they're not too tight either.
Old 12-01-2023, 09:32 PM   #17
David in San Antonio
David in San Antonio's Avatar
I was surprised to learn that the Model A’s front suspension is set with positive camber. That is, the tops of the wheels are farther apart than the bottoms. I understand this was done to reduce steering effort. Perhaps this was common practice at the time.
All modern cars use negative camber to enhance cornering grip. Power-assisted steering is ubiquitous so steering effort is a non-issue anyway.
1930 ('31?) Deluxe "Wretched Roadster"
Restored 1957
Alamo A’s Club
David in San Antonio is offline   Reply With Quote
Old 12-02-2023, 02:22 PM   #18
LEM
LEM's Avatar
My homemade tape measure front end alignment tool.
LEM is offline   Reply With Quote
Old 12-02-2023, 09:25 PM   #19
katy
katy's Avatar
Home made toe boards.
