Old 01-27-2021, 08:23 PM   #1
Ljpjohnson
Default Seat Removal
We have a 1929 Model A fordor Briggs leather back. I am recovering the seats and can’t see how to remove the back of the front seat and the side wings on it. Anyone have any suggestions or diagrams?
Ljpjohnson is offline   Reply With Quote
Old 01-27-2021, 09:24 PM   #2
Ruth
Default Re: Seat Removal
If I understand what you are asking, I don't think they are removable easily??
Ruth
Old 01-27-2021, 11:35 PM   #3
Cape Codder
Cape Codder's Avatar
I understand you said you had a '29 BUT on my '30 BRIGGS Blindback the back is nailed to the bottom wood all the way around. The material is stretched over the metal and nailed under the bottom wood. Hope that helps!
Cape Codder is offline   Reply With Quote
Old 01-28-2021, 05:40 AM   #4
Ljpjohnson
Thanks, Sounds like I won’t be able to take that out to recover it.
Old 01-28-2021, 05:41 AM   #5
Ljpjohnson
Thanks
Old 01-28-2021, 07:13 AM   #6
Daba
I have a 30- 3 window four door and a 31 s/w and they both are attached to the wood around the seat frame.
Daba is offline   Reply With Quote
Old 01-28-2021, 07:50 AM   #7
eagle
eagle's Avatar
I have a leatherback briggs. There is a metal bracket holding the seat back to the door pillar, about at upper arm height when sitting in the seat. The bottom seat frame is screwed to the floor. Take the side brackets off, remove the base screws, and the whole seat frame will come out.
Old 01-28-2021, 07:52 AM   #8
eagle
eagle's Avatar
I'm tall, so when I had my seat out I moved it back a couple inches. It did require fabricating new brackets for the seat back to door post.
Old 01-30-2021, 05:35 PM   #9
Ljpjohnson
Thanks, Sounds like this will work.
