Old 07-28-2020, 03:21 AM   #1
Werner
Werner's Avatar
Default Dimensions of hood edge protektor
Hallo und guten Morgen.
I am just sewing the protector-corners made of leather for the rear end of the lower engine hood.
Can someone please tell me the size?
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 07-28-2020, 08:51 AM   #2
Mike Peters
Mike Peters's Avatar
Default Re: Dimensions of hood edge protektor
The first two photos are an original AA truck with original rear hood corners. First photo is the outside, and second photo is inside the hood where the seam goes. The stitching is NOT exposed to the outside after installation. Both straight edges are 1 1/2"-1 5/8". The diagonal from the corner of the two straight edges measures 2". Use a tubular rivet with small washer upset on the inside of the hood. Sewing a pair of these should not be difficult. Use the thinnest leather you can find, so that it bends easily. Maybe cut some leather out of an old handbag?
The last two photos are new hood corners from Snyders, with rivets, washer, and instructions. See the small indent in the middle of the diagonal? When installed, the indent creates a nice rounded edge at the edge of the hood. Color is black.
Mike Peters is offline   Reply With Quote
Old 07-28-2020, 04:20 PM   #3
Werner
Werner's Avatar
Good evening Mike and special thanks for your helpful and very detailed informations!
Unfortunately I used leather that was too thick. Because of this, the seam cannot be turned backwards. But that's no problem. Maybe I'll do it again, it's not a lot of work.
Fastened with a copper rivet.
Werner
Citroen 11 CV, 1947
Old 07-28-2020, 05:24 PM   #4
Ray in La Mesa
You might try and source some soft leather glove material, I've seen some very thin & flexible.
Ray in La Mesa is offline   Reply With Quote
Old 07-28-2020, 06:00 PM   #5
Mike Peters
Werner: Your hood corners look very nice. No one will ever know they are not quite correct except you. mike
Thread Tools
Display Modes
