10-28-2019, 08:57 PM | #1 |
Rear Spring Perch - Welds
I have the rear end out of my '29 to install an overdrive and am trying to understand what I see with regard to the spring perches. In reading prior threads I understand it may have been common to weld and re-drill the perches. Is that what the attached picture looks like to you all?
10-29-2019, 01:10 AM | #2 |
Re: Rear Spring Perch - Welds
Yes, but a butchered job.you possibly could grind it down and redo?
10-29-2019, 08:12 AM | #3 |
seems the heat stresses would weaken the part versus strengthen it.
Building a '29 Speedster, the hard way... |
10-29-2019, 09:33 AM | #4 | |
MIG is my welding of favor. MUCH more inclusive weld and no inclusions from the shield material/substance. Many use TIG for the first pass to get the most inclusive weld possible. With proper pre-heat, checking as you go along with dye penetrant, and proper interpass temperature there should be NO cracking. Actually with 7018 filler/rod, your weld will be stronger than the original metal. I think a "re-do" is warranted though. A lot rides on that support. Joe K
Shudda kept the horse. |
10-29-2019, 11:48 AM | #5 |
A local Model A repair shop here in Southern California repairs worn spring perches by inserting a bronze rod the same size as the bushing and then filling in the worn void with weld. The weld won't attach to the bronze.
Tom Endy |
10-29-2019, 11:56 AM | #6 |
I sorta do the same thing but use gouging rods made of carbon. That way if anything gets stuck I can break it out I think they are 3/4 (maybe 7/8) and I get them from McMaster Carr But be awhile since I bought any. |
10-29-2019, 05:33 PM | #7 |
Copper rod it good too if you can find some. I've used copper for weld back ups quite a few times. I avoid using too hard a filler material. It makes it more brittle than it was originally.
