Old 11-23-2010, 06:22 AM   #21
Lowsquire
Lowsquire's Avatar
Default Re: repairing rear axle housing bearing races..
Sounds like a great way to go, especially if your needle roller bearings are toast as well, as they arent cheap either!
I would imagine a few minutes with a hub, and a vernier , and a good bearing catalogue would yield a workable combination..I think I need to ring some bearing Mfgs tommorow and get some catalogues sent out!
On This job I'll probably just use sleeves, as the bearings and outer races are perfect, but next one Ill try this out!
Lowsquire is offline   Reply With Quote
Old 11-23-2010, 08:08 AM   #22
Ralph Moore
Ralph Moore's Avatar
I too, would like to see the bearing mod.
Ralph Moore is offline   Reply With Quote
Old 11-24-2010, 12:19 PM   #23
Pothole Jim
Pothole Jim's Avatar
Since you are planing to have the housing machined, why not do the machining and convert to the newer ford axles. They sell kits to convert you housings to accept new slide in type ford axles with new bearings. You can also buy new housings already converted to new ford axles.
Hot rod works
Dick Spadaro
Pothole Jim is offline   Reply With Quote
Old 11-24-2010, 10:47 PM   #24
Ralph Moore
meric42,
Lets see those pictures/drawings of your bearing mod.
I'm getting impatient, sorry.
Old 11-25-2010, 06:45 AM   #25
PeteVS
PeteVS's Avatar
Originally Posted by Ralph Moore View Post
meric42,
Ralph: Sorry for the delay! Here's a link to Hot Rod Works. They do this kind of work.
http://www.hotrodworks.com/
Go to the Catalog section, Axle Upgrades and then either for Early Fod Brakes OR Modern Brakes.
Don't never get rid of nuthin!
PeteVS is offline   Reply With Quote
Old 11-25-2010, 07:07 AM   #26
Kerk
I had a pair of early 32 axles done and then went a different route. I would be glad to part with them for $ 300. + S&H kc
Kerk is offline   Reply With Quote
Old 11-29-2010, 07:03 PM   #27
meric42
meric42's Avatar
Finally here are the pictures I promised, sorry for the delay.
In the first pic you can see the inner spacer held in place by the factory inner hub seal cir-clip and the two ball bearings between which is another spacer @ 1/2" wide. There is a third spacer identical to the inner spacer but fitted on the out side of the outer bearing. The second pic shows the inner seal cir-clip and the inner spacer and the third pic is a close-up of the inner/outer spacer
The width of the spacers is not particularly critical, the complete set-up should be sized to fill the space right out to the seal retaining clip grove. The inner hub seal is no longer required as sealed bearings are used and should require no further lubrication.
Remember the bearings used are only a loose fit into the hub so a thin sleeve is required between the outside of the bearing and the inside of the hub. I have used loctite on mine to secure the bearings and prevent movement in the hub.
I hope the above explanation is clear, if not then please feel free to ask any questions. If anyone is interested I may be able to supply the bearings and spacers in the form of a kit with full instructions, just let me know if interested and I will price up the parts.
Kind regards, Meric42
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
http://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
Old 11-29-2010, 08:02 PM   #28
X38
Well, about time!
Thanks for that, of course now, it seems so simple!
X38 is offline   Reply With Quote
Old 11-29-2010, 08:17 PM   #29
Vergil
Vergil's Avatar
Thanks Meric42 for the pictures, I like it but it is to late for me now, if I do another banjo I would sure look at you solution.
Vergil
Bigger fonts to aid in reading
Vergil is offline   Reply With Quote
Old 11-29-2010, 08:22 PM   #30
meric42
meric42's Avatar
Wink Re: repairing rear axle housing bearing races..
Originally Posted by X38 View Post
Well, about time!
All good things take time, thanks for your patience.
Old 11-29-2010, 08:31 PM   #31
Teich
Used the races that Macs sell installed as instructed ie machined and a press fit. working quite well approx. 6000 miles no issues have machines buddy so lathe work was very reasonable he makes repairs like this for all types of machinery. this is probably just as strong as restubbing a large truck axle! Laurie
Teich is offline   Reply With Quote
Old 12-10-2010, 04:34 PM   #32
Ralph Moore
Meric42,
Do you have the #'s for those bearings? How do these work out on the road? I mean have you put some miles on them and noticed any improvement?
Ralph
Old 12-20-2010, 09:32 PM   #33
FlatheadTed
FlatheadTed's Avatar
We use The 2 bearing system here quite a lot, it works well but there's still machining involved ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 12-20-2010, 11:50 PM   #34
Fourdy
Fourdy's Avatar
pics please.
Fourdy
Fourdy is offline   Reply With Quote
Old 12-21-2010, 04:20 AM   #35
Mart
Mart's Avatar
Can someone that has done this twin bearing conversion be so kind as to quote the bearing numbers please??
Thanks.
Old 12-21-2010, 03:21 PM   #36
meric42
meric42's Avatar
Sorry, I can't quote the numbers without removing my bearings and I cannot give personal report as I have not yet driven my car with this mod. However I can report that a friend of mine had the same mod done to his '33 3 window coupe in 1995 and has had no problem with it and he is really happy with the end result.
Hope this helps.
Seasons's Greetings to you all.
Old 08-19-2013, 02:50 PM   #37
eicke
OK...just fired up the air compressor and blew the dust off this ole thread........anyone find a bearing number for this mod?
-Ron
eicke is offline   Reply With Quote
Old 08-23-2013, 08:57 PM   #38
Robert1936
Robert1936's Avatar
Some of you blokes worry too much.
The sleeves from Macs Etc are ok to use BUT you must have someone do the job who understands Limits and Fits. I think the reason that they make them thick is to accommodate those Backyarders who are not good machinists and use an old lathe to get the required size on the axle "close enough" and then press them on.
If the interference fit is excessive it puts a lot of tension in the sleeve and it will split if its not thick enough.
For those who worry about "weakening the axle housing" have a look at the cross sectional area of the wishbone extension where the front and rear springs attach, it would take just as much loading as the axle housing and you end up with still a lot more metal on the housing after turning /grinding them down.
Incidentally the housing should be turned and finally ground to give a suitably smooth and round surface to press the sleeves onto. Grinding produces a smooth surface while a lathe must always leave small grooves where the cutting tool moves along the surface. I've been a machinist in an aircraft factory and college teacher for 45 years
If the sleeves are "out of round" they will round up again when pressed on. They must have been round when they were machined in the first place.
I've used them and they are excellent.
Robert1936
Robert1936 is offline   Reply With Quote
Old 08-24-2013, 03:51 AM   #39
koates
Just some info on the rear hub roller bearings. The original genuine ford bearings had hardened end plates. Some modern replacement brands are not hardened on the end plates which causes metal to wear off them and mixed with the wheel bearing grease makes a lovely abrasive paste. Got a pair of new german made bearings supplied by macs which were not hardened. So ask the question before you buy them. Regards, Kevin.
koates is offline   Reply With Quote
Old 07-28-2020, 08:22 AM   #40
Locpk
Meric 42
would you please add my name also. Thanks
Locpk is offline   Reply With Quote
