Old 09-02-2014, 08:11 PM   #1
C4engr
C4engr's Avatar
Default Horn
Can I wire the HORN per the Model A wiring diagram and not use the Tail and Headlight portion of the Lighting Switch..??
C4engr is offline   Reply With Quote
Old 09-02-2014, 08:21 PM   #2
700rpm
700rpm's Avatar
Default Re: Horn
Original horn?
Ray Horton, Portland, OR
Old 09-02-2014, 09:06 PM   #3
C4engr
C4engr's Avatar
Default Re: Horn
700RPM..... YES original 1931 Horn..
Rog
Old 09-02-2014, 09:13 PM   #4
SteveB31
SteveB31's Avatar
Default Re: Horn
Yes you can.
SteveB31 is offline   Reply With Quote
Old 09-02-2014, 09:29 PM   #5
C4engr
C4engr's Avatar
Default Re: Horn
Thanks for the confirmation.... I will try doing that in the morning...
Have a great A Day....
Rog
Old 09-02-2014, 11:57 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Horn
Run the power wire to the cutout, then run the other horn terminal to the center contact on the switch plate. You don't even have to buy the lighting harness.
Old 09-04-2014, 11:04 AM   #7
C4engr
C4engr's Avatar
Default Re: Horn
Tom W....
I installed horn using your direction. Worked very well...
Thanks...... Rog
