02-06-2023, 03:00 PM | #1 |
putting oil in houdaille shock
How to go about putting oil in houdaille shocks on the car, what position should the arm be in ?
thanks kurt |
02-06-2023, 03:08 PM | #2 |
Re: putting oil in houdaille shock
"At rest" is best way to describe it I guess.
02-06-2023, 03:38 PM | #3 |
Kurt, I have found it helps to disconnect the arm and while filling the shock (drop by drop) move the arm up and down.
02-06-2023, 04:41 PM | #4 |
if there origl. shocks not rebuilt there is three typs of fluid to fill them with the filler plug shape tells you witch fluid to use.
02-06-2023, 08:11 PM | #5 |
02-06-2023, 08:21 PM | #6 | |
If I could sketch worth a darn, I would. I can't so I won't. Some shocks used a glycerin-based fluid while others used a mineral oil base. Still others used a castor-based fluid. Anyway, realistically, a guy is fine using hydraulic jack oil.
02-06-2023, 08:46 PM | #7 |
This page is from the 38-39 Ford book.
Combining mystery shock fluids can make cottage cheese. Confirm your fluid, don't believe what the filler plug tells you.
Alan |
02-06-2023, 08:46 PM | #8 |
Is the shock "full" when no more drops will be accepted?
02-06-2023, 08:51 PM | #9 |
Shocks, when mounted correctly, have a fill plug on the side like a transmission or a differential. It cannot be overfilled if the car is sitting on all four wheels.
Alan |
02-06-2023, 10:11 PM | #10 | |
....... and NOT on a San Francisco-like hill! Coop |
02-06-2023, 10:47 PM | #11 |
I always removed the shock, clamped it in a vise in the same angle as it was on the car to refill. I backed the adjuster off and added fluid then cycled the shock arm to expel any trapped air. then reset the adjustment to original position.
02-07-2023, 02:26 AM | #12 |
Clamping left and right shocks together in a large vise is a bit awkward, but is the best way to make adjustments to the pair. Push and pull both simultaneously to synchronize actions.
Alan |
02-08-2023, 07:22 PM | #13 |
The Hoo-Dies have a reservoir section and a hydraulic fluid transfer wing & stator section. If a shock has been regularly maintained, a person will know what's in it. Most folks use more viscous fluid in the older units now days due to wear between the stator and wing shaft that increases clearance over time.
If the unit still rotates then the fluid likely hasn't started to turn to goo quite yet, A person can remove and flush them with denatured alcohol to get whatever is in there out. Once they come clean they can be refilled with what ever works for hydraulic oil. Glycerin was used due to it's good all weather characteristics. Mineral oil tends to get thicker when it gets cold and thinner in hot weather where glycerin would hold it's viscosity pretty well in all temperatures. Glycerin does go bad after a period of time and starts turning into a dark messy goo substance and this is why a lot of folks use SAE 90 GL-1 gear oil or various hydraulic oils. I would consider using AeroShell 100 straight mineral motor oil since it is very well refined and is the same viscosity as SAE 90 gear oil. A hydraulic oil of similar viscosity could also be used. Viscosity depends on condition of the unit. The Ford Service Bulletins have a lot of info on caring for the rotary fluid dampers. |
