04-18-2021, 05:36 PM | #1 |
Model B bell housing numbers
Have 2 Model B bell housings with numbers on them. How can I identify them by numbers 1st one is B5II809I Second one is attached to Model B oil pan number is AB5002409. Have a Model B motor so trying to match up which one would be best. Are there any ID numbers on a Model B motor that I could look for? Thanks.
04-18-2021, 06:05 PM | #2 | |
Re: Model B bell housing numbers
04-18-2021, 06:40 PM | #3 |
Agreed with one minor quibble, namely that unlike with '32 V8 engine numbers where low engine numbers coincide with early production vehicles, nearly 40,000 Model B engine/transmission assemblies were produced before any were installed in vehicle production given the decision to postpone all '32 vehicle production until a production version of the V8 engine became available. There is ample evidence that that huge inventory of Model B engines was not used in vehicles on a first-in, first out basis.
The last Model B engine produced with the AB prefix was 5062386. From 5062387 upward, the prefix was simply B. |
04-18-2021, 08:15 PM | #4 |
Great Thanks. I will have a spare upper bell housing and want to use the less rare on a race car project when someone might need it for a proper restoration. So the question would be which one would be more desirable for a correct restoration? thanks.
04-18-2021, 08:45 PM | #5 |
I would think one that matched a frame number.
04-18-2021, 09:43 PM | #6 |
04-19-2021, 09:02 AM | #7 |
A word of caution do not put a B engine on an engine stand using the bellhousing as the attaching point. The cast iron housing will break causing the engine to fall.
A dangerous and tragic event( especially if it matches the frame number )
Early Ford Lock & Key Service http://www.fordbarn.com/forum/showthread.php?t=46583 |
04-19-2021, 11:05 AM | #8 |
Good counsel; V8s are at risk as well with that type of engine stand.
04-19-2021, 11:11 AM | #9 |
O.K. Just trying to get the spare bell housing to someone who would appreciate it for it's numbers. If it is a common part that's great. And yes thanks on the tip for mounting motor on a stand. I am pulling the motor out of storage and look for any numbers on it possibly identifying it. Was told it came from a 1932 coupe but who knows. Again forum is a great source of info!
04-19-2021, 02:40 PM | #10 |
Unlike Model A engine blocks, the '32-34 four-cylinder blocks normally do not have their engine numbers stamped on them. However, there is a noticeable casting variation on very early '32 B blocks. Once you have the subject engine out of storage, if you could take photo of the left side of the block, I can assist you in identifying if it is one of those very early blocks that might be a mate to your early flywheel housing or a run-of-the-mill subsequent block casting.
04-19-2021, 05:40 PM | #11 |
O.K. Will do. Will be out next week and will photograph the left side for ID and post it. Thanks again. Appreciate it!
04-20-2021, 07:42 PM | #12 |
Just to add.... you do see B motors with numbers stamped on them. David can correct me if I am wrong, but I believe those were usually replacement motors. I have a B block with an AA number stamped in it which came out of an AA truck.
Short URL: http://smu.gs/14g7eDW |
04-20-2021, 08:44 PM | #13 |
Jim,
You're right as some jurisdictions required that the engine block be stamped when the original was replaced, often with number sequences that bear little or no resemblance to Ford's numbering system |
04-20-2021, 10:49 PM | #14 |
Not to mention all the B-engines produced for industrial applications where the blocks were stamped by the end-user with numbers that devolved from their own operational asset designations. Out West, the railroads, mining, and timber outfits all had their own peculiar numbering systems for engines that were never destined for passenger car use.
04-23-2021, 10:20 AM | #15 |
Hi All. Got the engine out. Noticed a C stamped on the cylinder head with a small stamped C116 right in front on top of cylinder head. No stamping numbers on pad where you would expect a number. Here are some photos.
04-23-2021, 10:21 AM | #16 |
I am seeing I should pull cylinder head and check for cracks before I go any further with this motor. Any other areas to look for cracks? thanks.
04-23-2021, 03:21 PM | #17 |
Man....what a 'tease'! I'm one of THOSE guys, too! '58-'61? Wanna elaborate? DD |
04-23-2021, 04:35 PM | #18 |
Thanks for providing the photos of the B engine. The cylinder block is not one of the early versions; sorry.
If you pull the head, look for cracks between the valve seats and adjacent stud holes and more rarely encountered, between the valve seats and cylinder bores. |
04-23-2021, 04:42 PM | #19 |
Thanks for the reply. Now I know she is a later model so assume 1934! Yea forgot the Corvette was in the photo. Have had her since 1972. Was a drag car and brought her home as a basket case. Have a surviving photo of her when she was raced. Just found history on dealer she came from. That took over 40 years and many searches but now have her history. Still locating correct bits to make her more accurate. I will pull the head and check for cracks and get back to you.Thanks.
04-24-2021, 11:08 AM | #20 |
It's a '32, not a '33 or '34 four banger judging from the timing gear cover, crankshaft pulley, and front motor mount bracket, all of which are quite different on '33-'34 fours.
