10-23-2021, 04:17 PM | #1 |
Battery chargers or battery tenders ?
I'm sure someone here knows the answer...
I have a small lift that uses 4 - 6v deep cycle batteries, much like a golf cart. The factory charger failed, and I have replaced all 4 batteries new. Should I look for a 24v charger, 2 - 12v chargers. Or 4 - 6v charger / tenders? Since I don't get to the shop where this is at very often, and even then I don't use it much, but when I need it I'm out. If I just disconnect the short cables on top it the batteries. I can leave 2 in series for 12v, or disconnect all and have 4 independent 6v batteries. The prices seem about the same whether I buy an expensive 24v unit or 4 individual 6v models. I'm open for suggestions on this one for sure! Thanks 😉 |
10-23-2021, 05:40 PM | #2 |
Re: Battery chargers or battery tenders ?
Steve,
Deltran makes battery chargers/maintainers with 2 and 4 banks. Unfortunately, they are 12v only and are listed as currently out of stock. Perhaps you could put two 6v batteries in series and use the two bank unit when they are back in stock. You can go to the Deltran website to buy them. On it’s website Walmart has a Banshee 5 Bay 6/12v Smart Charger/Tender for Car Motorcycle Truck Boat Battery for $124.88: https://i5.walmartimages.com/asr/37e...2&odnBg=FFFFFF Good luck, David Serrano Last edited by California Travieso; 10-23-2021 at 09:06 PM. |
10-24-2021, 11:31 AM | #3 |
https://www.amazon.com/24-volt-batte...attery+charger
https://www.batterymart.com/c-24-vol...-chargers.html
10-24-2021, 12:26 PM | #4 |
If the batteries are all the same age (or new) and condition and the same brand, size, etc. then they can all be charged in series (24 volts). If not then there is a chance that one or more batteries will be overcharged because of one battery that is under performing. Overcharging is a quick way to kill a battery.
Check the voltage of each battery individually after they have been sitting for a day. If they are all equal within a tenth of a volt then you are good to go.
10-24-2021, 01:52 PM | #5 |
In general, size matters. In series, a large battery and a small battery will result in one being undercharged, or over charged. It matters less in the OP's case, as they are identical batteries. But even if the same size, there will be internal differences as they age. I'd think you'd be better off charging them in parallel, ie get a decent size 6V charger and run a small current through them, a smart charger that can taper would be best. Since 6V smart chargers are probably rare, the other option is 2 parallel banks of 2 in series on a 12V smart charger might be the best real world compromise, given what's out there in the market place. Just be aware that when in parallel, the pair with least resistance will draw more current, and the other pair will get less, and not be as charged. Buy 2 chargers and split the pair is the better and more expensive way. It sounds like one charger would be the least work, with less cable disconnecting.
Buy yourself a specific gravity battery tester, and check them twice a year. Add water if needed. If you see drops in one battery compared to others, charge that battery more while you're there. If you see one low cell and two good cells in a battery, it's going south. I have a friend that maintains his 6V deep cycle batteries over the winter on a solar cell. The (average) solar output is matched to the current needed to float the batteries. He's had very good luck doing that. Last edited by Mister Moose; 10-24-2021 at 03:18 PM. |
10-24-2021, 06:47 PM | #6 |
Solar panel voltage is higher when the panel is colder. So the highest output is on a clear winter day. The panel should be facing south (in the northern hemisphere) and in general mounted at an angle equal to the local latitude. And, of course, the panel should be in full sun. Even a partial shadow on a panel can kill all the output. This is because the cells are mounted in series. One cell if in shadow will block all the current from the rest of the cells. Large panels that put out 60 volts or so will have diodes to bypass any strings in shadow, but the output is still severely diminished.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 10-24-2021 at 06:58 PM. |
10-25-2021, 12:11 AM | #7 |
After reading everyone's suggestions and directions, I checked on Ebay and Amazon for specific 6v chargers and found enough 6v / 12v combinations with 4 banks. I believe this would be the best choice, as they are "tender friendly after charging it.
https://www.amazon.com/gp/product/B0...FCZQ3JX5&psc=1 |
