Old 06-27-2020, 12:02 PM   #1
Step-down
Step-down's Avatar
Default Offset piston in a 59 AB
So a 59AB I’ve been messing with has offset piston ,( all new) The crank has floaty rod bearings. Don’t know the history other then it was just rebuilt by unknown
Motor was overheating . I’ve pulled rust and clay out of the block, enough to fill
A peanut butter jar.
EveryThing been decked and harden valve seat .
Balance crank /Max 1 .Odd the block was cleaned
My question has anyone seen offset pistons in a 59AB
Advantage or dilemma
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 06-27-2020, 12:55 PM   #2
flatheadmurre
flatheadmurre's Avatar
Default Re: Offset piston in a 59 AB
It´s just part of the evolution...ford went there with the 8BA.
No reason not to use them as it´s what´s commonly on the shelf theese days.
Old 06-27-2020, 01:09 PM   #3
estout81
I think they were to reduce piston noise.
estout81 is offline   Reply With Quote
Old 06-28-2020, 06:41 AM   #4
Tim Ayers
Cleaning, as in dunking in a solution, does little to remove the crud from the water jackets as you found out. It take physical prodding, scraping, and poking to remove it. A bake blast cleaning and dunking are needed to really clean all that stuff out.
Good think you got it and please report back if the operating temp. improves.
Tim Ayers is online now   Reply With Quote
Old 06-30-2020, 04:02 PM   #5
alchemy
alchemy's Avatar
My engine was sandblasted through all the water jacket holes, cleaning the factory sand and aftermarket rust. I can cruise down the interstate at 65 MPH in the summer and it will show about 170 degrees on the gauge.
alchemy is offline   Reply With Quote
Old 07-03-2020, 03:54 PM   #6
Step-down
Step-down's Avatar
Cleaned out a jar of rust and clay
File Type: jpeg C36059AE-293A-4FCE-B147-FFBE3AB535B7.jpeg (23.1 KB, 32 views)
Old 07-03-2020, 03:55 PM   #7
Step-down
Step-down's Avatar
Held 20 lbs over night
File Type: jpeg 91AE679A-ACF0-40EE-9F29-D9FCA451688C.jpeg (25.9 KB, 24 views)
Old 07-03-2020, 05:27 PM   #8
Tim Ayers
Good to go, my man!!!!
Old 07-03-2020, 08:17 PM   #9
Ol' Ron
Ol' Ron's Avatar
Did you know the crankshaft is also Offset over an1/8". Wonder why the went to offset pistons.
