12-28-2019, 02:43 PM | #1 |
Reproducing Door Panel Retainer Nails ( A-35704-A )
I have been struggling on coming up with a way to accurately reproduce the head finish on the A-35704-A & B Door Cardboard Trim Retainer Nail using a reproduction nail as the platform for the modification. Has anyone successfully done this, -and if so, would you care to explain how you did this?
About the only method that is showing any promise to us is to replicate them on a 3D print station however the time element is the 'killer'. Does anyone else have any ideas or solutions?? . . |
12-29-2019, 10:35 AM | #2 |
Re: Reproducing Door Panel Retainer Nails ( A-35704-A )
This sounds like a pain. But if you can support the nail head fron underneath, then you can take a sharp punch and hammer the dimples into the nail head. The only way I can think of doing it. Have you tried "Restoration Supply" in California to see if they have these nails.
My thoughts. JP |
12-29-2019, 11:27 AM | #3 |
Not sure if I'm helping here. Are you after the dimple look? I just checked CS Osborne and their chart shows the dimpled style. I'm not sure of the head diameter but it looks like what you have in your picture.
12-29-2019, 11:45 AM | #4 |
If the nails were a softer metal it might be easier but they still have to be driven into the substrate. There are a lot of decorative upholstery nails/tacks available but most of them are likely larger than that. What is the diameter of the head? |
