Old 05-29-2020, 08:33 AM   #1
stude333
stude333's Avatar
Default hammer size
anyone have a recommendation on the hammer size for using the old ford stamps on hot rolled steel. or any other tips?
stude333 is offline   Reply With Quote
Old 05-29-2020, 08:34 AM   #2
stude333
stude333's Avatar
Default Re: hammer size
It is the 1934 commercial variety steel
Old 05-29-2020, 09:36 AM   #3
51 MERC-CT
51 MERC-CT's Avatar
Suggest you obtain some steel sheet of the same thickness to practice on.
And it would help to have a substantial steel backup in the location where installing.
Old 05-29-2020, 09:47 AM   #4
deuce_roadster
deuce_roadster's Avatar
When I use mine I clamp a thick piece of metal to act as a straight edge and rest the flat of the stamp shaft against it to make all the stampings in a straight line and not tilted. A heavy piece underneath if possible to back up the top rail of the frame and act like an anvil is a good idea too. I also using a silver sharpie, wrote "TOP" on the flat part of the stamp shank to avoid making a mistake and stamping something upside down or sideways. As for the hammer, I just use a medium sized ball peen. As suggested, practice on a scrap.
Old 05-29-2020, 09:48 AM   #5
19Fordy
19Fordy's Avatar
I like this one:
You only hit it one time. Practice first to get the feel and impact correct. I don't like ball pein style as the head is not flat. It has a slight crown. Layout in advance the punches you plan to use AND in the numbering sequence you require to help avoid mistakes. First, stamp the entire number on scrap metal to learn about spacing location and metal deformation. Place used numbers aside, away from the ones you are using. I know this all sounds a bit "OFF" but dumb mistakes can happen.
https://www.zoro.com/jackson-cross-p...iABEgJ6c_D_BwE
Old 05-29-2020, 09:50 AM   #6
19Fordy
19Fordy's Avatar
Sorry for double post.
Old 05-29-2020, 11:24 AM   #7
woodiewagon46
One think to remember is that there is no "from the factory" depth. I have seen stamped numbers that were very deep and easily readable to numbers that were almost unreadable. I guess if the guy doing the stamping was having a bad day, the frame is what he took it out on.
woodiewagon46 is offline   Reply With Quote
Old 05-29-2020, 02:20 PM   #8
Zeke3
Zeke3's Avatar
Looks like Henry used about an 8 oz. ball peen hammer on the first V-8. He was stamping on cast iron in this photo.
I haven't seen a straight, evenly spaced serial number on an early V-8 Ford, other than the I8.
File Type: jpg 1932_Henry_Ford_stamping_number_on_first_V8.jpg (46.3 KB, 51 views)
Zeke3 is offline   Reply With Quote
Old 05-29-2020, 02:30 PM   #9
KiWinUS
KiWinUS's Avatar
There is a nice plastic tool for holding stamps on the auction site
Old 05-29-2020, 02:33 PM   #10
19Fordy
19Fordy's Avatar
I suppose if the numbers were too straight it would raise questions.
Old 05-29-2020, 02:39 PM   #11
40 Deluxe
If you use a straight edge or a plastic holder, you are "over restoring". Do it freehand, like the factory! Plus, you've got about 10 seconds to get it done.
Old 05-29-2020, 09:56 PM   #12
Tinker
Tinker's Avatar
First I'll ask why are you stamping? They say bigger then a framing hammer and less then a sledge.
