Old 07-16-2016, 03:19 PM   #1
mshmodela
mshmodela's Avatar
Default Muffler Clamp
I noticed a few weeks ago my car sound just a tad louder than normal... Not like a hole in the muffler... well I think I found the source:
You can see the blacking near the clamp..
So are the muffler clamps etc from the suppler ok? I typically buy from Synders.
Thanks
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 07-16-2016, 03:23 PM   #2
goodoldvic
goodoldvic's Avatar
Default Re: Muffler Clamp
I would put a bolt and nut on that sucker and go
goodoldvic is offline   Reply With Quote
Old 07-16-2016, 03:23 PM   #3
Gary WA
Gary WA's Avatar
Yes good ones.
www.whidbeymodelaclub.com
Gary WA is online now   Reply With Quote
Old 07-16-2016, 04:01 PM   #4
700rpm
700rpm's Avatar
You need both bolts, make sure you have the manifold and muffler lined up perfectly, and that you don't have that clamp on upside down (it looks correct in your photo).
Ray Horton, Portland, OR
Old 07-16-2016, 04:34 PM   #5
mshmodela
mshmodela's Avatar
Great thanks all!
-Mike
Cleveland, Ohio
Old 07-17-2016, 12:38 AM   #6
Brentwood Bob
try brass nuts when you replace the missing bolt.
Bob
Brentwood Bob is offline   Reply With Quote
Old 07-17-2016, 11:11 AM   #7
mshmodela
mshmodela's Avatar
Bob
I've order a new clamp and copper gasket but for now, the bolt with the missing nut is in place (not lost) , so I've removed the other bolt and nut (amazing what a QTIP of PB Baster will do on threads) to get a matching replacement nut... The bolts and their threads are in decent shape so I might just see how that works... I'll see if I can find a bass nut locally --thanks!
-Mike
Cleveland, Ohio
Old 07-17-2016, 11:39 AM   #8
katy
katy's Avatar
Just use a standard steel bolt and nut and put never seize on the threads.
Old 07-17-2016, 12:00 PM   #9
1930artdeco
1930artdeco's Avatar
Is that clamp on correctly? It looks like it is upside down or am I seeing things?
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 07-17-2016, 12:47 PM   #10
Tom Endy
Tom Endy's Avatar
Bratton's sell a muffler paste that comes in a tube. Anytime I install a muffler clamp I put a bead of paste in the groove on each clamp piece. It makes a good seal when it hardens. If when I have reason to remove the clamp I clean out all the hardened paste and apply new.
Tom Endy
Old 07-17-2016, 12:52 PM   #11
Brentwood Bob
I believe #9 is correct. The smaller radius goes on the exhaust pipe side. And The clamp probably does not need to be replaced, so I would not buy parts until I diagnosed the problem.
Bob
Old 07-17-2016, 01:08 PM   #12
Patrick L.
Patrick L.'s Avatar
I usually use the inside sleeve along with a gob [ technical term] of exhaust paste when installing that clamp. I also double nut them just for the heck of it.
And as said, the joint needs to line up almost perfectly.
Old 07-17-2016, 01:17 PM   #13
C26Pinelake
Tom Endy
Smart man that Tom Endy! Wayne
C26Pinelake is offline   Reply With Quote
Old 07-17-2016, 02:26 PM   #14
Tom Wesenberg
Tom Wesenberg's Avatar
The clamp looks correct as pictured. The longer taper goes down.
I use a dab of muffler cement around the inside of the pipe flange.
Old 07-17-2016, 03:05 PM   #15
mshmodela
mshmodela's Avatar
I could not find any brass for now I grabbed some stainless and added two lock washers...
Did not over tighten it... just snug.... Silenced up the car! I wonder if the car might have been sucking in some of the exhaust from the Zenith (if so, if possible, a heat/less oxygen feedback if you will....)
She drove fine..
-Mike
Cleveland, Ohio
Old 07-17-2016, 04:03 PM   #16
Mitch//pa
Sucking the exhaust back into the carb can foul the plugs black
Old 07-17-2016, 04:40 PM   #17
Y-Blockhead
Y-Blockhead's Avatar
I wouldn't use stainless without anti-seize. It may gall and you will have a time getting it off again.
Old 07-18-2016, 08:21 AM   #18
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
"Someone" is making clamps that doesn't require NUTS. The Dog saw them "somewhere" while he was surfin'----
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 07-18-2016, 03:11 PM   #19
ModelABum
ModelABum's Avatar
Any thoughts about the best way to orient the clamp? One part front, one part back; or one inside, one outside; or obliquely oriented; or doesn't matter at all? I've seen it all different ways, but obliquely seems more common in my experince.
ModelABum is offline   Reply With Quote
Old 07-18-2016, 04:16 PM   #20
Joe K
Joe K's Avatar
Think about how it might have been assembled in the factory.
https://www.youtube.com/watch?v=PZnGWJ_6BwU
If it was easy for them - then perhaps orient it to be easy for you?
Of course according to the video, the body was off when the muffler was attached.
Joe K
Shudda kept the horse.
