Old 03-09-2021, 01:51 PM   #1
lannysv
Default exhaust manifolds identification
I have a set of Y-block exhaust manifolds and cross-over that I need help identifying as to fitment. The numbers are EBU-9430-B and EBU-9431-C. They were on a 1954 256 cid Mercury but the Mercury parts manual uses the prefix EBY for 1954 instead of EBU. I am guessing that they may be for a 239 cid, but I cannot translate the U identifier. Help?
lannysv is offline   Reply With Quote
Old 03-09-2021, 02:10 PM   #2
dmsfrr
dmsfrr's Avatar
Default Re: exhaust manifolds identification
This link is all I've got...
http://www.y-block.info/casting/exhaust.html
Old 03-09-2021, 02:24 PM   #3
KULTULZ
KULTULZ's Avatar
Post Re: exhaust manifolds identification
ENGINE SERIES IDENTIFIER -
EBU 1954 239CI PASS CAR (DIF)
EBV 1954-55 239CI TRUCK ENGINE (CLV)
EBY 1954 256CI FORD PI - 1954 MERC - 1954-55 TRUCK (CLV)
That ID SYSTEM was used before FORD went to the P&A SYSTEM 1957-58 on where the CASTING ID NOS Prefix were four character,
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 03-09-2021, 04:37 PM   #4
darrell
as far as fit goes they will interchange with all y blocks
darrell is offline   Reply With Quote
Old 03-09-2021, 08:46 PM   #5
dmsfrr
dmsfrr's Avatar
But not necessarily into different vehicles, due to the fit around other parts under the hood.
Old 03-09-2021, 09:35 PM   #6
KULTULZ
KULTULZ's Avatar
Question Re: exhaust manifolds identification
Now you wonder if it has the correct engine ...
- WHY IS IT ... -
Old 03-10-2021, 12:45 PM   #7
lannysv
Thanks for all of the comments. I can now be fairly certain to market them as 1954 Ford 239 while still fitting a 256, 272, and 292, depending on which heads match with the size of openings.
