02-11-2021, 03:51 PM | #1 |
Need help ID'ing this synchronizer
I found this transmission synchronizer in my "stuff" and would like to know what year, make Ford car it fits. It was tagged 1940 to 48 but, I am not sure that's correct as it sure looks different from the 1940 versions I have seen. I don't see any balls, springs , inserts or spring clips like the 40's used.
THANK YOU. |
02-11-2021, 04:02 PM | #2 |
Re: Need help ID'ing this synchronizer
There's balls and springs in there, I think some versions had more, 32-38ish had the integral blocker rings
02-11-2021, 04:03 PM | #3 |
https://www.ebay.com/itm/Rebuilt-ori...gAAOSw~oFXM98M
1932-39 Ford transmission clutch hub synchronizer 48-7124 From 1935fordtn's ebay site...
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 02-11-2021 at 04:10 PM. |
02-11-2021, 05:26 PM | #4 |
1932-38 used the same hub, but the outer sleeve came in two flavors. There was the first version that measures 1.406” width (front to rear). Then in 1935 Ford changed the outer sleeve to a slightly narrower dimension of 1.345” wide. You have to match the sleeve to the cluster gear in the transmission. The early sleeve (B-7106) goes with the B-7113 cluster gear. The later sleeve (48-7106) goes with the 48-7113 cluster gear.
02-11-2021, 05:32 PM | #5 |
I will sell it, now I know what I have. It's NOS. Hopefully, someone can use it. |
