03-18-2015, 11:30 PM | #1 |
52 Mercury Carburetor
I'm assuming it is a Holley on the stock 52 Mercury. Not too surprisingly after a 30+ year rest the carb has issues. Seems like only one side is working well as it needs a bit of choke to keep running and stalls easily when dropping into gear. When I spray a shot of penetrating oil into the right side venturi it smooths out and picks up rpm briefly so I'm assuming the right side circuit is blocked. I'm reluctant to take it apart for cleaning without a repair kit on hand for the gaskets that will likely break on dis-assembly. Anyone know the model number of this carburetor?
https://www.youtube.com/user/roosty6/videos |
03-19-2015, 03:22 AM | #2 |
Re: 52 Mercury Carburetor
I think you have a better chance with the gas can put on the cowl so it will get the
pump going (gravity) what you have is the 4 bolt (mount) Holley called a tea pot. they are easy to take apart slowly without breaking gaskets. I find to loosen screws and soak in a bucket of gas to soften the gaskets. Running on half a bank sounds like the venturi's plugged up. Then clean with lacquer thinner keep the acc pump soaked to swell it. These were used on big truck Y blocks, so theres lots of kits around. as far as the model I'm not in the shop now gotta look it up. I got rid of those on my trucks & got an adaptor for a square bowl later 2300 Holley problem over. sam |
03-19-2015, 06:19 AM | #3 |
Ralph,
For a no excuses kit try DAYTONA PARTS 386 427 7108. Over the years things like carbs get switched...you know the story. The HOLLEY back draft carb is #885-FFC used '49-late '51 and occasionally on some '52's ( I just finished one on a '52 ) and the HOLLEY tea pot late '51- '53 #1901-FF. Charlie ny |
03-19-2015, 09:59 AM | #4 |
