Old 05-11-2021, 10:20 AM   #1
Neshkoro
Neshkoro's Avatar
Default Radiator/ water pump
I have a leak either in the water pump or the radiator. With the car running with one side of the hood open, I get spatter on the windshield and the firewall. I tried replacing the rope seal in the water pump. That did not do anything to stop the leak. I can't see any place in the radiator that is leaking. I have new radiator hoses that I still have to install.
Here's the question.
Has anyone ever used Bars Leaks or a similar radiator stop leak product in a Model A?
I've used it in modern cars with relative success.
Thoughts?
Thanks.
Neshkoro is offline   Reply With Quote
Old 05-11-2021, 10:27 AM   #2
JayJay
Default Re: Radiator/ water pump
Thoughts?
Thanks.
Someone put some Bars Leak into the radiator of my pickup, totally gummed up the tubes such that I had to find an "old school" radiator shop that knew how to work on brass radiators to rod it out. Keep in mind that Bars Leak works in part by the pressurized cooling system forcing the goo into small leaks, and you don't have a pressurized cooling system in a Model A.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
JayJay is online now   Reply With Quote
Old 05-11-2021, 10:42 AM   #3
J Franklin
J Franklin's Avatar
If you want to use a stop-leak use one that is in dry powder form like AlumaSeal.
Old 05-11-2021, 11:10 AM   #4
alexiskai
alexiskai's Avatar
I wonder if you could rig up a temporary shroud for the water pump, like the leather ones I see on some cars, that would block the fan draft and allow any leakage to collect there or drip down the block. Then you'd know which piece was leaking.
Old 05-11-2021, 09:49 PM   #5
1crosscut
1crosscut's Avatar
I don't think that you need to go the stop leak route just yet.
First off is your radiator cap gasket in good shape?
Are you by chance filling the radiator to the top (too full) and coolant is overflowing out the overflow tube and picked up by the air flow?
A dry paper towel is your friend here. Use it to dab around the hose fittings, water pump shaft, bushing and mating surface to the head.
If it is leaking from a hose, your water pump or elsewhere you should be able to find it with the paper towel or toilet tissue.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 05-12-2021, 05:49 AM   #6
Neshkoro
Neshkoro's Avatar
Good thought!
Thanks for the idea.
Old 05-12-2021, 06:58 AM   #7
Conaway2
Conaway2's Avatar
Two thoughts -
On the water pump, I’ve rebuilt a number of pumps with a new stainless steel shaft and modern o-ring seal that all the vendors sell - no more leak issues or fiddling with the original type seals that always eventually leak.
Radiator - I;ve gummed up more than one radiator as a teenager by using stop-leak products. a good radiator shop can clean and repair your radiator for less than a new one. In fact, I’m picking up an original A radiator from a local shop today....the cost will be $125.
Good luck - Jim
Conaway2 is offline   Reply With Quote
Old 05-12-2021, 08:28 AM   #8
1931 flamingo
1931 flamingo's Avatar
Disconnect the fan belt and run it. This eliminates the w/pump and if the rad is leaking you should be able to see it. Use a bright light.
Paul in CT
Old 05-12-2021, 09:14 AM   #9
Y-Blockhead
Y-Blockhead's Avatar
I once had a small leak that was driving me nuts trying to find. Mine only leaked when sitting overnight and cold. When running it didn't leak. I found it when I removed the radiator shell and found a crack on the front side where top tank is soldered to the tubes.
Old 05-12-2021, 11:42 AM   #10
Neshkoro
Neshkoro's Avatar
I'm going to try the AlumaSeal first. If it fixes it, I'm good. If not, I'll keep looking.
