Old 12-20-2011, 05:49 PM   #1
lotsagas4u
Default 1933 ford Jacking?
What is the best way to jack up a 33 coupe? Floor jack under middle of front axle? Then jack stands on the frame behind the front wheels? Floor jack to where on rear axle housing? Would hate to damage from improper jacking, thanks
lotsagas4u is offline   Reply With Quote
Old 12-20-2011, 06:04 PM   #2
jimTN
Default Re: 1933 ford Jacking?
You can jack up either end by putting a jack in the center of the axle. I would put stands under the front axle unless you are planning on pulling it.
jimTN is online now   Reply With Quote
