Old 12-19-2011, 09:58 AM   #21
Ed Solari
Default Re: 1935 6V Battery Help Needed
Yea
I noticed last month that the optima battery ...which is made by Johnson Control , move production to mexico. If you want to leave a message about this here is the link. You pay premium price and when transferred to Mexico there is no price reduction
http://www.johnsoncontrols.com/publi...ns/brands.html
Ed Solari is offline   Reply With Quote
Old 12-19-2011, 10:22 AM   #22
1931 flamingo
1931 flamingo's Avatar
Logic says the price should have increased. Now it's "imported".
Paul in CT
Old 12-19-2011, 11:23 AM   #23
Shadetree
Shadetree's Avatar
My left exhaust pipe interfered with installing the Optima in the original position in my `35. So I put under the right side of the hood resting on the frame. I used the existing holes in the frame to secure it. It would be an easy switch to put it back for the purist. It is nice too to have a cut-off switch I can get to in a hurry.
Shadetree
Son, you will never blow an engine up in high gear.
Shadetree is offline   Reply With Quote
Old 12-19-2011, 08:18 PM   #24
G.M.
I also used the existing hole in the frame and one of the inner fender panel bolts on the 35 plus a clamp type on the vertical firewall stiffner on the firewall leg. I didn't want to drill holes either. I remounted about 8 batteries with Optima's and used existing holes on all of them. On the 39 P/U I made a Optima box with a place for several oil bottles that is held in the original battery holder by the battery hold down bolts. Another green cut off that was also replaced by a heavy duty from Bob Shewman G.M.
www.fordcollector.com
Old 12-20-2011, 12:11 AM   #25
FlatheadTed
FlatheadTed's Avatar
Thats a nice set up GM ,I wonderd about the one near the mufler for heat .
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 12-20-2011, 05:41 PM   #26
G.M.
It's a long way from the muffler, I waould say at least 3 inches. The camera angle makes it look closer. G.M.
